Wire Wheel / Cast Wheel Swap
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
In doing my swap, it looks like 2017 EX wire wheels and 2014 DLX cast wheels can be easily swapped using OEM parts. 2014 DLX and 2017 EX use the same rear disc. Others use a different part number that may work fine, or a new disc will be needed. 2013 models also have a rear axle issue addressed below.
This is a list of 2017 EX wire wheel parts for the 2014 DLX. Use your old F & R calipers and axles, rear disc, sprocket and dampers. Prices were found online at well below suggested retail from hondaparts-direct.com:
Front:
wheel assembly ...........$523
pulser ring and bolts ........22
L & R disc rotors ...........610
12 disc bolts ...................17
tube/rim strip................. 25
L & R wheel spacers ........15
Front subtotal ...........$1212
Rear:
wheel assembly ...........$615
tube/rim strip .................28
L & R wheel spacers ........26
caliper bracket ................97
brake hose .....................37
drive flange ..................128
pulser ring and bolts.........55
speed sensor..................116
rear subtotal .............$ 1102
If you have a non-ABS 2013/2014 model, you may need to shim the right front disc outward 2mm because a pulser ring isn't used. On a 2013 ABS, the speed sensor is mounted into the right caliper bracket, and later bikes have a separate bolt-on bracket. The front pulser ring has a different part number, so the speed sensor location/spacing may be different. But there are ways to check or compensate.
At the rear wheel of either 2013, the 25mm axle causes problems compared to the 20mm on the later bikes. You would need to use the later 20mm axle and chain adjusters, and make spacers where the axle passes through the swingarm - with a 2.5mm wall thickness, they would be a little fragile. Or use a later swingarm.
I went the other way, putting 2014 DLX cast wheels on my 2017 EX. It was a bolt-on using OEM parts. Only slight problems were caused by speed sensors. The rear speed sensor wire was shorter than the original, and needed to be carefully routed and secured. The front had too large an air gap, but I didn't check it beforehand. I was able to put 0.5mm shims/washers between the separate speed sensor bracket and the fork leg.
The cast front wheel weighed 20.2 lbs with discs.
The wire-spoke wheel weighed 16 lbs with discs - add 1 lb for the tube.
The cast rear wheel weighed 18 lbs with disc.
The wire-spoke wheel weighed 17.5 lbs with disc - add 1 lb for the tube.
Net weight reduction is 2.7 lbs. I used my shipping scale, so only fairly close.
This applies primarily to US 2013, 2014, and 2017 models, and probably Canadian models. Check with your local parts department to be sure.
05-04-2020, 06:49 AM
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
RE: Wire Wheel / Cast Wheel Swap
2017 EX with 2014 DLX wheels and 2014 standard tank and seat, Arrow exhaust.
05-04-2020, 09:53 AM
peterbaron Offline
Likes Given: 996
Very informative and good job Thumbs Up
05-04-2020, 10:20 AM
Likes Given: 789
That looks really good PD.
05-04-2020, 01:01 PM
Ben70_imp Offline
Threads: 23
Very nice looking!Thumbs Up
Ben
05-04-2020, 01:24 PM
Likes Given: 1,012
The best of a number of worlds. It looks great.
05-04-2020, 04:53 PM
Desert viper_imp Offline
Threads: 7
Looks great Joe....side covers came out perfect also
05-04-2020, 05:25 PM
Jfro5687_imp Offline
Threads: 23
Very very nice
05-04-2020, 07:21 PM
Houtman_imp Offline
Threads: 115
Thank you for that great info , are the ABS pulser rings the same and work with the modulator ?
05-04-2020, 08:55 PM
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
(05-04-2020, 08:55 PM)Houtman_imp Wrote: Thank you for that great info , are the ABS pulser rings the same and work with the modulator ?
You will need new pulser rings front and rear.
05-04-2020, 11:23 PM
  wheel swap cad cnc lazer reluctor for speed sensor 1973cb750 13 3,188 10-28-2025, 05:56 AM
Last Post: 1973cb750
  Wheel Chocks DAC 8 795 07-22-2023, 10:23 AM
Last Post: DAC
  An update on my spoke wheel conversion. FLYTYM_imp 20 1,336 06-17-2023, 02:09 AM
Last Post: FLYTYM_imp
  Wire colors not matching the diagram (2013 A / 2017 NA)? LayerCake_imp 16 1,349 05-30-2022, 05:45 AM
Last Post: LayerCake_imp
  Ignition switch live accessory wire? ozigoo 10 886 02-18-2021, 02:32 PM
Last Post: ozigoo
  best sprocket swap for city commuter acceleration... boynton6spd_imp 3 376 12-04-2020, 12:35 PM
Last Post: 17-CB-002
  Houtman's new wheel chock The A-man 14 1,076 07-04-2019, 07:05 AM
  modifying wheel trim misterprofessionality 18 1,453 05-14-2019, 02:49 PM
  cb1100 RS wheel conversion misterprofessionality 34 2,590 04-26-2019, 03:59 PM
  tank swap nckcrdn_imp 4 525 03-14-2019, 12:18 PM
