CB1100RS handlebars
jtopiso_imp Offline
Threads: 13
RE: CB1100RS handlebars
(08-08-2018, 04:32 PM)jtopiso_imp Wrote:
(08-05-2018, 05:42 PM)jtopiso_imp Wrote:
(08-04-2018, 09:11 AM)MaFiHa_imp Wrote: https://sw-motech.com/en/products/ergono...bar+riser/
Those are a little bit pricey but I ordered it for my RS, too. 15 cm.
High quality
Are there more elegant solutions? Are there replacement parts for the lower halves of the clamps, with different heghts?
(15cm seems a bit too much. Check your units! Big Grin)
What I mean, are there alternative pars to "13" on the diagram?
Is there a taller version (and/or with different longitudinal offset) to part-no "53132-MEJ-000"?
https://www.bike-parts-honda.es/honda-mo..._1/2/25246
Hi,
Still looking... with no results.
If anyone knows of a lower clamp that is compatible with our CBs and makes the handlebar position to be a bit closer to the rider, please let me know.
I am a bit reluclant to installing one of those risers, so that's my last option.
Also: if I take the "risers route", can you confirm the bar diameter?
Thanks.
09-17-2018, 05:04 PM
Cafe Project_imp Offline
Threads: 4
Get in touch with Cognito Moto, they can fabricate just about anything for a CB front end. They are well priced and very responsive. I have GSXR 750 swap for my CB1100 that they made for me. If you need stock 2013 CB 1100 anything for the front end, I have it all for sale...(plus all of the rear end).
Bars are 7/8
09-21-2018, 12:53 PM
Moe_rider_imp Offline
Threads: 2
What’s the stock RS diameter? At grips & controls parts
11-15-2019, 09:34 PM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Received: 199 in 118 posts
Likes Given: 142
Should be 7/8 inch. All the others models are.
11-16-2019, 12:51 AM
Ulljanrich_imp Offline
Threads: 3
Just to let you know:
on my CB 1100 RS I used this one to get the handlebars
a) higher 30mm and
b) closer to driver 21mm
https://voigt-mt.de/Lenkererhoehung-30mm...RS-mit-ABE
The quality is really first class. The risers are manufactured in South Germany and no China cheap Aluminum. Black anodizing also first class.
I had no problems with the length of cables.
Only thing I had to do with the cables: on the right side of the front frame-triangle I had to unclip the rubber-brake-hose from its attachment clamp and then secure it with a nylon cable ties again.
It woul dhave worked without that change but as it is a brake part, no need to have any tension on that, for zero risk.
That is invisible and safe with no effect on the functionality and security. My Honda dealer does it exactly that way when he does this hightening of handlebars.
11-19-2019, 08:10 PM
Charlie Bravo_imp Offline
Threads: 30
#26
On many bikes I've owned, I made risers out of 1/2" drive 19mm sockets and placed them under the OEM bar mount. They're chrome, round, inexpensive, and fit perfectly with just a longer bolt, but YMMV.
11-26-2019, 05:58 AM
  Taller Handlebars DBM_imp 7 767 03-27-2022, 03:42 AM
  handlebars Crossfire_imp 2 348 03-15-2022, 11:29 PM
  Grab bar for 2017+ CB1100RS Endeavour_imp 10 886 09-17-2021, 10:12 PM
  Wider handlebars, Tracker style. JLEECB 18 1,914 05-16-2021, 09:31 PM
Last Post: Zee9_imp
  09 CB900 Hornet handlebars ozigoo 6 558 07-24-2020, 04:03 AM
Last Post: max
  Side mount plate number CB1100RS Moe_rider_imp 0 293 11-03-2019, 07:54 PM
Last Post: Moe_rider_imp
  Things I have done list.cb1100rs 2017 Chris potato_imp 3 372 07-14-2019, 05:18 AM
Last Post: Chris potato_imp
  Narrower Handlebars pekingduck 4 524 10-08-2018, 03:43 PM
  Type 2 Handlebars Installed Capo 4 484 09-21-2018, 07:02 AM
  In search of those elusive handlebars. FLYTYM_imp 8 684 07-06-2018, 03:03 AM
Last Post: 3rdbike_imp
