Narrower Handlebars
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
Narrower Handlebars
I've been looking for a pair of slightly lower, narrower chrome handlebars that were the right diameter to fit the stock dampener weights. I had previously installed CB919 bars on my 2013, but they were 4" narrower than stock, and 1.5" lower. Fine on the highway and canyons, but a little too narrow around town.
So on my 2014, I raised the seat by having an upholstery shop almost an inch under the stock cover, so the bar to seat height was effectively lowered (and my knees were less kinked).
But the bars were still too wide, so I loosened and pushed the master cylinder and clutch cylinder as far inboard as practical. It was only an inch on either side, but to make a noticeable difference at freeway speeds (less of a sail), without losing the levereage around town. I did have to redrill the holes for the switch locating pins and for the bar weight retainers. Amazing how a little change makes a big difference.
10-08-2018, 09:37 AM
chync_imp Offline
Threads: 20
Narrower Handlebars
Honda makes a type ii handlebar for the cb1100 that is exactly what you are looking for. Samurider sells it.
10-08-2018, 10:45 AM
dbarkdoll_imp Offline
Threads: 22
RE: Narrower Handlebars
Yup. Love my Type 2 bars. A bit pricey but worth every penny IMO.
10-08-2018, 11:11 AM
Guth_imp Offline
Threads: 125
Yes, the Type II bars would have been almost exactly what you were seeking — before the seat mod that is.
[Image: b00d3974e7d57abaf3338f941c323597.jpg]
In the end, your solution was probably better for you as you benefited from the raise in seat height. I liked the ratio of the seat height to handlebar height as the bike came from the factory. But a lower seat height worked to my advantage so I ordered both the Type II bars along with the lower Japan market seat.
10-08-2018, 03:04 PM
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
(10-08-2018, 03:04 PM)Guth_imp Wrote: Yes, the Type II bars would have been almost exactly what you were seeking — before the seat mod that is.
Thanks Guth for that pic. It's pretty hard to compare handlebars verbally, and the pic answers a lot of questions. It looks to be the same bend, 2" narrower on the bottom portion. Samurider describes it as 70mm, which is about 2.75". Not sure if that means 70mm lower, 70mm height, or if it was meant as 70 cm, the width. I'll have to inquire with them.
10-08-2018, 03:43 PM
  Taller Handlebars DBM_imp 7 765 03-27-2022, 03:42 AM
  handlebars Crossfire_imp 2 348 03-15-2022, 11:29 PM
  Wider handlebars, Tracker style. JLEECB 18 1,908 05-16-2021, 09:31 PM
Last Post: Zee9_imp
  09 CB900 Hornet handlebars ozigoo 6 551 07-24-2020, 04:03 AM
Last Post: max
  CB1100RS handlebars cooky6660_imp 25 1,668 11-26-2019, 05:58 AM
  Type 2 Handlebars Installed Capo 4 483 09-21-2018, 07:02 AM
  In search of those elusive handlebars. FLYTYM_imp 8 671 07-06-2018, 03:03 AM
Last Post: 3rdbike_imp
  New more comfortable handlebars geosar_imp 27 2,085 05-22-2018, 05:47 PM
  Switching handlebars 3rdbike_imp 17 1,129 04-25-2018, 11:38 PM
  Who also installed these clubman handlebars from Dime City Cycles? chync_imp 4 442 03-25-2018, 08:11 AM
Last Post: chync_imp
