Wider handlebars, Tracker style.
JLEECB Offline
Threads: 8
I’ve scoured the site for more information on handlebar swaps, and I’m a bit at an impasse in my decision. Most of the information is related to risers, not actually wider handlebars. I need wider than stock, I’m constantly putting my hands on the bar weights for more width. I love the positioning of tracker bars so that’s what I’m going with. The obvious issues are clutch and brake line, throttle cables.
I’m finding the exact dimensions of stock handlebars to peg down, best I can figure their 30 inches wide, 5.5 inch rise, and 7 inch pullback. Yes? I’m looking at 2 bars, one recommended by a Facebook CB1100 user, I’m unable to contact him for more clarity. The other I came along by chance and Really like.
http://power-barn.com/lsl-flat-track-bar-handlebars/
This one is the likely choice for minimal investment. It’s cheaper, and I think can be done without any changes (maybe only needing handlebar holders turned 180 degrees). 33 inch width, 4.5 rise, 7.4 pullback.
https://britishcustoms.com/collections/a...9162011744
This one I really want. Perfect width at 35 inches, 3.75 inch rise, 7 inch pull back. Double the price of the lsl, seriously doubting the ability to stretch the brake that far. The bar could be cut down, but if im not using the full length I might as well go with lsl.
Looking for thoughts, suggestions, things I might have missed.
As I understand, replacing the brake line requires replacing all lines, not just To the splitter. I see spiegler makes a brake line kit, and there are kits on webike, but I can’t tell if those are cut to exact dimensions as current brake lines or do they give more play? I’d prefer not to run two lines all the way down as well.
I haven’t seen much on throttle cables and how much play there is with rerouting. Anyone with experience on it?
https://imgur.com/gallery/rjnZWCy
07-19-2019, 04:54 AM
LongRanger_imp Offline
Threads: 129
RE: Wider handlebars, Tracker style.
Another source for bars is Flanders Company.
07-19-2019, 07:13 AM
JLEECB Offline
Threads: 8
(07-19-2019, 07:13 AM)LongRanger_imp Wrote: Another source for bars is Flanders Company.
I looked over the Flanders bars after you mentioned them. A couple of the 1” were nice, but none of the 7/8’s really tickled my fancy. Still torn between the lsl and Mule. I’m leaning LSL just because of cost effectiveness.
07-20-2019, 07:00 AM
JLEECB Offline
Threads: 8
I bought the Mule handlebar on sale from partzilla. Decided I’m gonna go with what I really want and make it work. Mechanic and I looked it over and think we can make it work by rerouting only. If not, stainless here I come.
A couple thoughts on the bar, looking for input.
It’s not knurled at the risers/clamps. Anyone else have issues with smooth bars or do I need to rough them up at the clamps?
I’d like to go with bar end mirrors, sans the Honda bar weights. I never had issues with vibrations with my cb750 and wide bars, but I never took it long distance like I take my CB11. Mechanic talked about pumping the bar full of silicon for dampening. A little more research and I heard about the bar snake, lead weights, sand. Anyone with personal experience on these tricks?
07-23-2019, 08:00 AM
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
I think you will need to rough the bars up, or they likely will spin at the clamps. I've used an automatic center-punch to put a whole bunch of dimples in the bar.
07-23-2019, 11:21 AM
Likes Received: 616 in 276 posts
Likes Given: 788
Great idea with the punch Pd
07-23-2019, 11:30 AM
JLEECB Offline
Threads: 8
Great idea, thanks. Does that mean the risers/clamps are Aluminum then? When I was searching for bars I read something on biltwells website that said knurl/dimples should only be used with aluminum clamps, that it won’t bite into steel clamps and reduces surface area for pressure.
(07-23-2019, 11:21 AM)pekingduck_imp Wrote: I think you will need to rough the bars up, or they likely will spin at the clamps. I've used an automatic center-punch to put a whole bunch of dimples in the bar.
07-23-2019, 12:03 PM
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
Almost all handlebar clamps are aluminum, so the dimpling or serrations are necessary on anything other than low bars.
07-23-2019, 12:29 PM
JLEECB Offline
Threads: 8
Ok thanks Peking. I’m actually quite hungry for roast duck now after reading your name.
Anyone with info/experience on the alternative dampening methods?
07-24-2019, 01:35 AM
JLEECB Offline
Threads: 8
I was looking at heated grips on amazon. Accidentally clicked buy on oxfords. Figured it must be a sign so on they went.
Turned out to be almost no issues. The Napoleon bar end mirrors extend forward a hair and force the levers to be a little further away from the grips. stock tubes and cables were just fine.
Right side a little busier than I’d like with all the cables, but the comfort level with hand and arm position is fantastic.
I didn’t try filling the bars. If I feel vibration issues I might try something down the road. Will put up more pictures when I get it home and cleaned up.
Also, how do I get my pictures to show instead of just linking them?
https://imgur.com/gallery/oYz1xm0
08-15-2019, 06:01 AM
  Rebel 500 SE style fairing? LayerCake_imp 0 298 06-12-2022, 09:03 AM
Last Post: LayerCake_imp
  Taller Handlebars DBM_imp 7 716 03-27-2022, 03:42 AM
  handlebars Crossfire_imp 2 337 03-15-2022, 11:29 PM
  09 CB900 Hornet handlebars ozigoo 6 535 07-24-2020, 04:03 AM
Last Post: max
  CB1100RS handlebars cooky6660_imp 25 1,661 11-26-2019, 05:58 AM
  Exhaust upgrade for riding style?? Skypilot_imp 35 2,306 04-14-2019, 08:00 AM
Last Post: Stichill
  Lucas Style Tail Light ArizonaKid_imp 3 353 02-10-2019, 09:57 PM
  '80's style appropriate front fender ideas misterprofessionality 6 656 01-17-2019, 11:02 AM
  Vintage style tires Matt F._imp 8 686 11-05-2018, 03:24 AM
Last Post: Matt F._imp
  Narrower Handlebars pekingduck 4 506 10-08-2018, 03:43 PM
