Early 80’s handlebar clamp
peterbaron Offline
Likes Given: 1,014
RE: Early 80’s handlebar clamp
That's gonna look good and professional when completed. No rush and take your time Thumbs Up
08-19-2020, 10:42 AM
Bheezy27403_imp Offline
Threads: 39
Nice work. You can now sleep at night knowing it lines up.
08-19-2020, 10:44 AM
PowerDubs_imp Offline
Threads: 125
(08-19-2020, 10:44 AM)Bheezy27403_imp Wrote: Nice work. You can now sleep at night knowing it lines up.
Thanks.
I'm probably the only person that would notice if I didn't point it out to them...but that's not how I roll.
Biker
08-19-2020, 11:09 AM
Likes Given: 807
(08-19-2020, 10:39 AM)PowerDubs_imp Wrote: So far so good.
I am certainly no machinist, I am just using a bench vice, a socket to keep it somewhat lined up and a Milwaukee cordless drill with a grinding bit.
I do have two large 240 V compressors and a die grinder, but I don’t wanna make a lot of noise and bother my wife and honestly for something like this slower is probably better.
[Image: 72dcb79fe90b53fab7f17d2f371504df.jpg]
[Image: 32c342999082e0aae3b36b922eba6c2b.jpg]
Still need to do the other side and then polish before spraying the clear.
and you don't even get your nails greasy...amazing.
08-19-2020, 12:26 PM
Desert viper_imp Offline
Threads: 7
(08-19-2020, 02:43 AM)Alain Lee_imp Wrote:
(08-19-2020, 02:15 AM)Desert viper_imp Wrote: Here is mine
Hi Desert Viper, a quick question.
Did you purposely omit the 4 chrome bolt caps or you like it better without the caps.
Regards
Alain Lee
On mine, the upper cap & lower bridge are flush (Perfect fit) Side to Side and Front to Back.
I guess HONDA can reuse older parts bins just like the horn.
[Image: 6f4aa73759fbacc8693298fbc416cdd2.jpg]
[Image: 931e287d002eb66672817214063a4339.jpg]
Regards
Alain Lee
[Image: 376c35e62166f69b11b7d25992a352ab.jpg]
[Image: 1269cf69cebf7a0cf488a4159efd825e.jpg] I just felt it looked more period correct with my Whitehouse K10 kit to leave them off.
08-20-2020, 12:11 PM
Threads: 125
#26
I am super bummed out.
Just had some spare time to get back to this.
Got the piece where I want it 95%
Radiused the corners which was easier said than done because of a taper from the top down all the way around.
Sanded and sanded and sanded. Especially after putting black into the letters. Very fine lines, pita.
I have spent a LOT of hours on this... sacrificed a stock clamp to grid off of, lost a clamp bolt cap too. Ugh.
Was thinking I just need one more session with the next finer grit of sand paper to match, then clear enamel.
Figured I’d throw it on the bike to see what it looked like before I do that.
[Image: 29036a96bf049c1bf908212e3ef3e78b.jpg]
[Image: a7f9b4a5f18b717da66f22ff4c93ca47.jpg]
I was NOT expecting it to be too wide.
There is no way around this. Sad
Into the garbage it goes.
Will need to order a new stock clamp and bolt cap cover.
Going to pour a stiff drink.
[Image: 8a8d52c6034985c3b6ad01131ccf1766.png]
10-07-2020, 10:39 AM
Likes Given: 1,029
#27
Maybe two stiff drinks?
Bummer.
10-07-2020, 02:16 PM
Ninemeister_imp Offline
Threads: 4
#28
It's an easy item to CNC machine should there be a demand...
Happy to engineer for free and organise at cost price if we can get a group buy going?
Regards
Alain Lee
Seems like this is the clamp from a Honda CB450 SC Nighthawk. There are a few for sale on eBay.
10-07-2020, 09:17 PM
KiowaEagle_imp Offline
Threads: 36
#29
(10-07-2020, 10:39 AM)PowerDubs_imp Wrote: I am super bummed out.
Ouch! That's a rough one. Sorry that happened Josh. Sad
10-08-2020, 12:27 AM
Threads: 125
#30
(10-07-2020, 09:17 PM)Ninemeister_imp Wrote: It's an easy item to CNC machine should there be a demand...
Regards
Alain Lee
I’m in.
[Image: 28203662b274867c98e24e9e3651ef98.png]
10-09-2020, 02:01 AM
  USB ON HANDLEBAR - connection at battery direct . Alfgaxatico_imp 38 2,973 05-17-2026, 10:20 PM
  Quad Lock handlebar vs clutch perch and bar-end mirrors Uncle Sixer 1 333 01-04-2026, 01:26 PM
  Handlebar control symmetry Uncle Sixer 17 1,780 08-07-2025, 05:24 AM
  Handlebar Risers?? bubblerboy64_imp 16 1,578 07-16-2022, 06:04 AM
Last Post: calipo223_imp
  What to do with the handlebar mounts when converting to clip-on controls? misterprofessionality 7 767 04-08-2022, 03:41 AM
  CB 1100 EX Handlebar original or other? MALACAY_imp 4 556 04-03-2022, 01:00 AM
  Handlebar from 919 motorider6_imp 10 970 05-27-2021, 12:47 PM
Last Post: Stichill
  CRF1000 handlebar mspaansnl_imp 0 238 05-25-2021, 04:57 AM
Last Post: mspaansnl_imp
  HANDLEBAR RISERS - is really necessary??? Alfgaxatico_imp 19 1,525 12-16-2020, 10:40 PM
  More handlebar talk - Samurider Type 2 replacements GrabOn_imp 10 1,057 07-23-2020, 01:16 AM
Last Post: KiowaEagle_imp
