LED Flasher Relay
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 136
RE: LED Flasher Relay
Go, did you mean pulse width modulated?
03-04-2021, 01:23 PM
(03-04-2021, 01:23 PM)Lord Popgun_imp Wrote: Go, did you mean pulse width modulated?
Yes. I wasn't allowed to correct it. I think another member used the correct term as well, possibly in another thread.
Thx Lord!
03-04-2021, 01:30 PM
Lord Popgun Offline
Virginia
Likes Given: 136
LOL, I was thinking Hardy looked up PCM and is wondering what the heck it has to do with LEDs Big Grin
03-04-2021, 11:17 PM
(03-04-2021, 11:17 PM)Lord Popgun_imp Wrote: LOL, I was thinking Hardy looked up PCM and is wondering what the heck it has to do with LEDs Big Grin
Yeah, I still grapple with autofill and PCM is definitely wrong. Maybe if the CB1100 could transmit data or music - then heh, yeah.
In any case, looking at the later posts, it is not unreasonable to look at a weakly held relay too. I have seen relays "weaken", maybe because of premature failure, though seldom for sealed units.
03-04-2021, 11:42 PM
hardylt_imp Offline
Threads: 1
It's not a bad idea. However, since it is almost a new bike (<1000 miles) I would hope the relay isn't already failing. Plus, the stock signals had no such flicker. What I suspect is more an issue with the LED's, not being designed to work at two different illumination levels, running and flashing. I get the sense these particular signals just have two states--flashing and off. But I also have a very limited understanding of LED's so I'm not sure.
03-05-2021, 01:37 AM
Lord Popgun Offline
Virginia
Likes Given: 136
#26
Hardy, did you check your PM? Let me know if you want a diagram.
03-05-2021, 01:47 AM
hardylt_imp Offline
Threads: 1
#27
(03-05-2021, 01:47 AM)Lord Popgun_imp Wrote: Hardy, did you check your PM? Let me know if you want a diagram.
Just saw it. Much appreciated!
03-05-2021, 01:51 AM
#28
RE relay: Moisture getting inside the relay (if traditional and not solid state) can happen while the device sits in a warehouse before assembled onto the CB1100 subsystem. This could, for example, oxidize the relay contacts.
RE LEDs: This could be a subsystem (your schematic diagram should reveal) that has a small processor that controls the mode of operation of the LED arrays. The logic is probably fine. It is the driver that could be having a bad experience. Maybe a marginal ground connection?
03-05-2021, 02:43 AM
hardylt_imp Offline
Threads: 1
#29
Maybe! This is the part where I am in over my head. I'll be checking my ground connections. But I have an LED relay from POSH coming in the mail now, plug and play with the stock connectors. We'll see if that does the trick. Thanks for the help thus far.
03-06-2021, 11:22 AM
#30
Good luck. Keep the "old" relay - if it is at fault. Many times they can be salvaged with a little electrical contact cleaner so long the coils are still healthy and used as a spare.
03-06-2021, 12:51 PM
  Flasher Unit built to a price ? 17-CB-002 15 1,312 03-27-2019, 02:12 AM
  Flasher - Buzzer installation on a 2017 CB1100 17-CB-002 12 908 01-15-2019, 12:26 PM
  Rear brake light flasher. walrusz06_imp 15 1,027 01-18-2017, 08:56 PM
Last Post: Rocky_imp
  She's a flasher PowerDubs_imp 12 900 09-06-2016, 05:09 AM
  Brake light modulator/flasher in a bulb dBuster_imp 7 646 06-24-2014, 03:20 AM
Last Post: Ridem32_imp
  Has anybody installed flasher relay for led signals? Romo1969_imp 7 506 04-18-2014, 11:12 PM
Last Post: Romo1969_imp
   Have you installed a headlight modulator (and with or w/o solid state relay)? rjk555_imp 22 1,362 11-28-2013, 02:34 AM
Last Post: rjk555_imp
  Brake Flasher Deanohh_imp 7 594 11-06-2013, 10:09 AM
