She's a flasher
PowerDubs_imp Offline
Threads: 125
She's a flasher
09-03-2016, 04:15 AM
Threads: 125
She's a flasher
75 views and no comment? I'm surprised.
I have this same kit on my ZRX, and think all bikes should come like this from the factory.
It makes the blinkers into additional tail and brake lights. Still orange lens, but light up red, brake red, blink orange. Looks stock when off.
09-04-2016, 07:59 AM
Randy B Offline
Palm Bay, Florida USA
Threads: 85
Likes Given: 133
RE: She's a flasher
(09-04-2016, 07:59 AM)PowerDubs_imp Wrote: 75 views and no comment? I'm surprised.
Didn't notice what I was looking at (as I suspect was the case with everyone else).
09-04-2016, 08:23 AM
Likes Received: 618 in 276 posts
Likes Given: 788
RE: She's a flasher
I thought it was normal and was waiting for someone to ask what was different about it so I didn't look goofy (like I normally do)
09-04-2016, 09:22 AM
treytexag_imp Offline
Threads: 5
RE: She's a flasher
I viewed it. Wasn't sure either what the video was attempting to demonstrate. Do the turn signals blink or flash while the brake light is illuminated? I really can't seem to make out the "functionality" being shown here.
Please explain what we're looking for. Thanks.
09-04-2016, 03:14 PM
Threads: 125
RE: She's a flasher
(09-04-2016, 03:14 PM)treytexag_imp Wrote: I viewed it. Wasn't sure either what the video was attempting to demonstrate. Do the turn signals blink or flash while the brake light is illuminated? I really can't seem to make out the "functionality" being shown here.
I know the video wasn't production studio quality, (7-8 year old phone sitting on a box)... but once explained it should be easy to see. As mentioned above, the blinkers are now additional tail and brake lights. Still orange lens, but light up red, brake brighter red, blink orange. Looks stock when off. Your blinkers just blink. You have 1 tail and brake light. This kit makes 3. In theory increasing your safety by 200%.
09-05-2016, 01:35 AM
metallyguitarded_imp Offline
Threads: 62
RE: She's a flasher
Increasing safety (in theory) by 200% is a rather ambitious statement. But thanks for posting the video and explanation. Any increase in visibility is worthwhile. Good to have another option for people to consider.
I have to admit, I watched the video and didn't see what was being demonstrated either. After I read your explanation, I watched it again and will just accept the fact that it's likely more noticeable in person. From the video quality, I couldn't tell if the blinkers were lighting up when you activated the brakes or whether there was simply reflection being cast from the brake light onto the blinkers.
09-05-2016, 02:37 AM
Hawkeye_imp Offline
Threads: 3
RE: She's a flasher
Appears to be a great safety idea as it should increase visibility while braking.
Wondering how does it "light up red" while still blinking orange? Also, is it available as a kit or is it a DIY modification?
Lastly, I was considering a flashing brake light module, and also wondering if this would work in conjunction with a flashing module?
Thank you.
09-05-2016, 02:59 AM
Threads: 125
RE: She's a flasher
It increases visibility during normal driving as increased tail light area as well as when braking.
It is a DIY kit. Here is a write up I did when I put it in my ZRX-
http://www.zrxoa.org/forums/showthread.p...-installed
Note the new link to the kit at the bottom of that post.
I don't see any reason it wouldn't work with a flashing module.
It is pretty simple- the light rings are red LED, so when they are on the light is cast red. When the blinkers are on, the light rings shut off.
On the ZRX the install was easy. On the CB, it required me to cut the metal support piece inside the blinker that goes from the base to the clip on the side to fit the ring. I can take pics of what I did if anyone is interested. I also coated the back of the light rings with liquid electrical tape since the base inside is metal. There was no need to do any of that on the ZRX.
09-05-2016, 03:36 AM
BayAreaRick_imp Offline
Threads: 4
RE: She's a flasher
This is what I use to 'increase visibility' from the backend. Had them on my CB750-Nighthawk and moved them over to the CB1100.
http://www.lights.skenedesign.com/P3_Features.shtml
Easy enough to install.
09-05-2016, 11:36 PM
  LED Flasher Relay hardylt_imp 79 5,670 06-10-2021, 04:31 AM
Last Post: hardylt_imp
  Flasher Unit built to a price ? 17-CB-002 15 1,360 03-27-2019, 02:12 AM
  Flasher - Buzzer installation on a 2017 CB1100 17-CB-002 12 924 01-15-2019, 12:26 PM
  Rear brake light flasher. walrusz06_imp 15 1,114 01-18-2017, 08:56 PM
Last Post: Rocky_imp
  Brake light modulator/flasher in a bulb dBuster_imp 7 685 06-24-2014, 03:20 AM
Last Post: Ridem32_imp
  Has anybody installed flasher relay for led signals? Romo1969_imp 7 535 04-18-2014, 11:12 PM
Last Post: Romo1969_imp
  Brake Flasher Deanohh_imp 7 612 11-06-2013, 10:09 AM
Last Post: rjk555_imp
