Has anybody installed flasher relay for led signals?
Romo1969_imp Offline
Threads: 17
I actually bought one that is specified for honda. Figured there would be a spare unused plug that was obvious. Not so much. Anybody know where to plug this thing?
04-14-2014, 12:48 PM
Threads: 17
Nobody?
04-17-2014, 10:57 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Received: 200 in 118 posts
Likes Given: 142
RE: Has anybody installed flasher relay for led signals?
A power source? There is an accessory plug by the battery and one in the headlight shell.
04-17-2014, 11:18 AM
Tyke57nz_imp Offline
Threads: 8
(04-17-2014, 11:18 AM)Lord Popgun_imp Wrote: A power source? There is an accessory plug by the battery and one in the headlight shell.
Are these on the pre 2014 machine and if so where are they. Are they coloured; is the information in the manual?
04-17-2014, 01:01 PM
Randy B Offline
Palm Bay, Florida USA
Threads: 85
Likes Given: 133
Those flashers are designed to replace the existing flasher unit, not to be used as an "add on".
04-17-2014, 01:36 PM
Lord Popgun Offline
Virginia
Likes Given: 142
They are colored. But at the moment I can't remember what color and am not near the service manual. If you remove the headlight you will see the connector as it is the only unused one in there. The battery one is the same.
If no one chimes in, I'll look after work. And yes, pre-'13 model. I would expect the '14 to be the same, but I haven't seen a '14 service manual.
04-17-2014, 09:50 PM
Lord Popgun Offline
Virginia
Likes Given: 142
Just so you know, I'm only posting about the accessory connectors. Sounds like RandyB knows about the flasher relay question.
Anyway, the connectors are red and should be capped. They have a green ground wire and a black/brown 12v wire. As always, you should verify with a multimeter as just because its on the internet, doesn't mean its true Wink
04-18-2014, 04:37 AM
Threads: 17
(04-17-2014, 01:36 PM)Randy B_imp Wrote: Those flashers are designed to replace the existing flasher unit, not to be used as an "add on".
Randy
Do you know where that flasher unit is? [Image: f3104287d6f442d7b2e3e5abe4c4c962.jpg]
04-18-2014, 11:12 PM
  LED Turn Signals deuce17EX 23 2,404 03-12-2024, 10:58 AM
  Has anyone installed a louder horn? Doug Shepard_imp 36 2,928 01-29-2024, 05:14 AM
  I installed the Emgo Reverse Cone Universal slip on danieljrmurray_imp 2 402 05-15-2023, 04:29 AM
Last Post: 3rd Gear Steve
  LED turn signals Elipten_imp 32 2,585 01-05-2023, 05:15 PM
Last Post: CptMoustache_imp
  Any aftermarket Turn signals plug and play? gretle_2.0 5 704 05-30-2022, 07:05 AM
Last Post: bioman_imp
  Turn signals option USA in EU Łukasz_imp 7 724 02-08-2022, 12:18 AM
  Identify these? Turn signals RandyBMC_imp 3 386 11-11-2021, 09:23 PM
   Traxxion AR-25's installed... great upgrade!! Sparky80_imp 2 364 10-18-2021, 12:38 AM
Last Post: Sparky80_imp
  LED Flasher Relay hardylt_imp 79 5,913 06-10-2021, 04:31 AM
Last Post: hardylt_imp
  Hepco & Becker Luggage Installed CaptainChris_imp 61 4,368 12-12-2020, 11:51 PM
