LED turn signals
Juancho76_imp Offline
Threads: 2
RE: LED turn signals
(04-04-2021, 12:02 PM)mvk24_imp Wrote:
(04-04-2021, 12:00 PM)Juancho76_imp Wrote: I have recently added the posh led relay. I also opted to add the motogadget pins for the front turn signals and motogadget disc for rears.
Good news...they do not hyperflash! Relay works great.
However, I do have a new issue.
Front pin leds, turn signals, hazards and running lights, GOOD.
Rear disc leds, turn and hazard good...NO running lights?
Now to figure out why? Anyone have similar issue and solutions?
The rear turn signals are not running lights 9n our bike, only the front turn signals are running lights.
Well....that information would have saved me considerable time and cussing had I asked hours ago! Lol
Thanks, it did cross my mind but for some reason I thought they were constant running before I cut them.
Appreciate your reply!
04-04-2021, 12:10 PM
mvk24_imp Offline
Threads: 18
Likes Received: 2 in 1 posts
Appreciate your reply! No prob! The only light that should be a running light on the rear is the tail light.
How was it wiring those bar end turn signals? Did you drill the bars?
04-04-2021, 12:29 PM
Threads: 2
I realized after removing the factory lights I had to fill the voids.
I chose the pins in the previous front light location. Rear lights were replaced with the disc.
I did play with the idea of adding the bar ends but chose not to last minute. The old location of lights would need to be cut off and painted. Maybe down the road I'll add to the bar ends?
I'll add some pics when completed
04-04-2021, 12:39 PM
mvk24_imp Offline
Threads: 18
(04-04-2021, 12:39 PM)Juancho76_imp Wrote: I realized after removing the factory lights I had to fill the voids.
Ah okay so you used the bar end disc's on the original factory mounting locations?
04-04-2021, 12:40 PM
danz76_imp Offline
New to the Forum
Threads: 0
Will one posh flasher relay suffice for all 4 blinker lights?
Or will I need one for the fronts and one for the rears?
11-10-2021, 11:06 PM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
#26
Just one. It replaces the OEM module.
11-10-2021, 11:13 PM
olafurarason_imp Offline
Threads: 7
#27
Hi. Can you please share your experience and tell me if this 90015-WR POSH flasher unit will fit CB1100 EX 2016?
https://japan.webike.net/products/24231555.html
On webike web site it´s indicated for 2010 - 2014 but often it will fit newer models. I just want to be sure before purchase.
BTW. Why is the 2016 model being dropped so often in web spare parts stores?
Thanks in advance.
11-03-2022, 05:04 AM
Lord Popgun Offline
Virginia
Likes Given: 142
#28
It should fit. However, one member in Denmark installed one and noticed his front blinkers were on all the time. In the US front signals must be on all the time and flash when the signal is activated. The Posh unit works like the stock US unit for lighting.
I don’t know about your country, but be ready for the fronts to be on all the time. The flasher module does all this and is internally wired or programmed to do so. The OEM unit is different in different countries, depending on their laws.
11-03-2022, 05:59 AM
Threads: 7
#29
(11-03-2022, 05:59 AM)Lord Popgun_imp Wrote: It should fit. However, one member in Denmark installed one and noticed his front blinkers were on all the time. In the US front signals must be on all the time and flash when the signal is activated. The Posh unit works like the stock US unit for lighting.
Thank you for your answer. In my country it´s not legal obligation to have the front signals on all the time. Are there another led flasher modules around without this deficiency that can be used instead of this Posh one?
11-03-2022, 10:00 AM
Lord Popgun Offline
Virginia
Likes Given: 142
#30
As far as I know, and have seen on the board, the Posh unit is the only one. And I thought they had discontinued it some time ago.
11-03-2022, 10:26 AM
  LED Turn Signals deuce17EX 23 2,395 03-12-2024, 10:58 AM
  Any aftermarket Turn signals plug and play? gretle_2.0 5 690 05-30-2022, 07:05 AM
Last Post: bioman_imp
  Turn signals option USA in EU Łukasz_imp 7 699 02-08-2022, 12:18 AM
  Identify these? Turn signals RandyBMC_imp 3 384 11-11-2021, 09:23 PM
  Anyone fitted Rizoma iRide turn signals to CB1100EX? Richard_imp 8 822 05-20-2020, 09:58 PM
Last Post: Richard_imp
  Lockhart Phillips Turn Signals-Lucas Tail Light ChipBeck_imp 43 3,321 04-17-2020, 07:25 AM
Last Post: gman_imp
  RELOCATION OF REAR TURN SIGNALS ART_imp 28 2,061 02-08-2019, 01:50 PM
  Self canceling turn signals Obleo 19 1,149 04-24-2017, 08:10 PM
Last Post: Tezza_imp
  Replacement turn signals Mikestib1_imp 5 580 11-19-2016, 10:48 AM
Last Post: flynrider
  Hard bags without moving the turn signals glynb_imp 3 335 07-29-2016, 09:52 PM
