Chains and Sprockets
(08-05-2014, 12:49 PM)Randy B_imp Wrote: Keep in mind that these are O-Ring chains and the rubber does wear out and that will be part of the stretch you are getting. And for me, personally, replace the sprockets with the chain. It's like replacing only one gear in a differential because it is the only one with broken teeth. The chain and sprockets wear in together and putting a new chain on old sprockets is only going to shorten the life of the new chain.
Appreciate the information Randy. I am living back in 1983 when there were no O ring chains so I dont know anything about them. It could be the chain never saw I drop of lube over the years until I got it. I just dont know. Or maybe age has gotten to the o-rings? It 11-12 years old now. I am with you on replacing all of it all at once though. I wont cut a corner on something like that.
The original Nighthawk chain is a cheap " market" chain. Very low tensile strength and wears out quickly. A new x ring chain has tremendous tensil strength and due to being packed with lube and sealed with x rings, will go 20-30,000 miles with minimal care.
Like you I am old school and was poor. We had to fix rather than replace. Guess that is why I still plug tires, and use clip style master links. My sprockets looked good so I just replaced the chain, although it is recommended they be replaced together. Again, sometimes I don't always do what is " recommended".
One word of caution when crimping a staking type master link. Too much pressure and you can creat a stiff link that cannot be fixed. Chain is ruined. Well, the link is ruined, it could be driven out and a new staking type link installed. Fine line between just right and too tight. Best to let someone who has some experience to stake a chain for you if you've never done one IMO.
Also keep in mind that a lot of the "stretch" in a chain is actually the sprockets wearing. The grooves might look good, but they become too deep and thus require more distance to tighten the chain back up.
Food for thought.
(08-05-2014, 01:06 PM)The ferret_imp Wrote: The original Nighthawk chain is a cheap " market" chain. Very low tensile strength and wears out quickly. A new x ring chain has tremendous tensil strength and due to being packed with lube and sealed with x rings, will go 20-30,000 miles with minimal care.
I did not know that Ferret and expected better from Honda but thank you for passing it along. I dont feel near as bad now. Everybody cuts some corners I guess. Im a tightwad and like to extend and milk the last drop out of everything I am probably going to replace the whole deal. That way, I know I am sure and know what I have. I honestly dont ride hard at all. Sometimes I get on it a little bit but not that often honestly. I can say for certain that I am not the cause of the premature wear.
(08-05-2014, 01:13 PM)Randy B_imp Wrote: Also keep in mind that a lot of the "stretch" in a chain is actually the sprockets wearing. The grooves might look good, but they become too deep and thus require more distance to tighten the chain back up.
Food for thought.
Did not know that either. Appreciate the lesson. I see where this is headed read quick. New sprockets and a new chain to be sure.
That wasn't my experience. The OEM chain on my Nighthawk was a pretty sturdy DID O-ring. It lasted 21K miles. I replaced it with a similar DID O-ring, which went....drum roll....21K miles. They probably would have gone further if I'd bothered to clean them. Dirt build up wears the O-rings like sandpaper.
Chain life has a lot to do with how you treat them. My buddy and I both replaced our Nighthawk chains and sprockets at the same time. His only went 11K miles. He never lubed it and always kept it at the tight end of the spec. I lubed with a light silicone every 3-400 miles and kept it at the loose end of the spec.
Quote:One word of caution when crimping a staking type master link. Too much pressure and you can creat a stiff link that cannot be fixed. Chain is ruined. Well, the link is ruined, it could be driven out and a new staking type link installed. Fine line between just right and too tight. Best to let someone who has some experience to stake a chain for you if you've never done one IMO.
Excellent point. Chain manufacturers will list specs for the flare on the master link. My chain started with the link pin at .215" and the target was .225. I had to work the chain riveting pin a bit, pull the tool off, measure with calipers, work it some more, repeat. Although chains are sturdy, the rivets require a very light touch. I think I made about 5 passes per link pin.
Flynrider, you did good on your Nighthawk chain. I think most original chains back then were generally good for about 12,000 miles.
I disagree ( respectfully) about the valleys between teeth getting deeper. As chains stretch they try and climb up over the top of the tooth, elongating the valley towards the front and eventually making the top of the tooth curved and pointy.
When I worked in the industry we would have guys come in and say their clutch was slipping, and an inspection would show the rear sprocket so worn, there were nothing but nubs left where sprocket teeth used to be. Seriously the teeth would be worn clean off the sprocket, and the chain would have nothing to grab.
I have seen it both ways. The Nighthawk I bought the year before I got the 1100 I didn't inspect the sprockets close enough before I bought it and rode it home and noticed the chain was "a bit loose". Like push up and touch the swing arm loose, and then some. I went to adjust it and found more than a couple broken teeth and I could tell that the grooves were too deep. That was the first time I'd run into that, but it does happen.
(08-05-2014, 10:02 PM)Randy B_imp Wrote: I have seen it both ways. The Nighthawk I bought the year before I got the 1100 I didn't inspect the sprockets close enough before I bought it and rode it home and noticed the chain was "a bit loose". Like push up and touch the swing arm loose, and then some. I went to adjust it and found more than a couple broken teeth and I could tell that the grooves were too deep. That was the first time I'd run into that, but it does happen.
After inspecting mine today it appears to me that the groves are deeper than they should be. I always remembered the teeth being worn badly in the direction that it pulls. Heck, I remember even back in the old days that we would turn the sprockets around to try to get more out of them. ROFL
Im ok for the next little bit but I am going to go ahead and get what you guys suggested. Problem is, I am so busy right now I dont have time to work on it and I wont pay anybody to do it either. I dont want to miss out on any riding either. In the perfect world, I would like to make it till winter so I dont feel like I am missing anything. I almost wish my back tire was worn out before I get into all of this but again I am a hard head and I think I can probably get another 3-4K out of it.
Looks like I am going to get about 12500 out of the original chain set which is about spot on to what Ferret said. I could not control the first 7K on this motorcycle so I just dont know how it was ridden. One thing is for sure though, My local Honda dealer will not make a sale nor will they lay a wrench on my Nighthawk ever. I dont think they know just how badly they pissed me off with their no test ride policy.ROFL They are brand new in my town and we have gotten off on the wrong foot. I wont rehash all of it in my chain thread but these idiots fail to realize the greatest inventions ever were the wheel and then the internet. You can buy anthing online at the drop of the hat with advice from other like minded motorcycle enthusiasts.
Ordered the chain and sprokets yesterday per Flynriders recommendations. I think the bill was 170.00 give or take. I dont have the tool to change this out and it will run 45.00-50.00 give or take. I emailed a local independent shop that will do it for 120.00. I have no experience with these new type chains and I am in a delima.
Since I have no experience with type chain would I be better off to pay somebody an extra 70 bucks or so? I hate to do that but I dont want to ruin a 120.00 chain either. I just hate paying somebody for something I think I can do but I am unsure in this case. But how do you learn? Is 120 reasonable?
Appreciate any advice. I am such a tightwad sometimes cant see the forrest for the woods but money is money. Can I do this or should I just pay up?
It is all easy to change your self but if you do not have the tools and a torque wrench and do not want to do a lot of servicing your self in the future than just pay the price and enjoy the bike.
I try to do most of the things myself but sometimes you need an better mechanic than you are your self.
A few weeks ago I had a carb problem with my 94 CB 1000 (run too strong carb cleaner thru the tank, BG 44 K)
Could not get it to run right and after $602 repair bill from great Honda mechanic, including parts , it now runs perfect again.
It was worth spending the $$$$.
Know your limitations !
  Center stand and new chain / sprockets jermo47_imp 8 848 04-24-2024, 10:55 PM
Last Post: jermo47_imp
  O-ring chain vs racing chains Klamathonian_imp 29 2,463 10-17-2023, 08:05 AM
  Milage when replacing chain and sprockets Frulk_imp 8 609 02-11-2023, 03:29 PM
Last Post: Frulk_imp
  AFAM Chains Maturecheese_imp 8 795 12-18-2022, 05:51 AM
Last Post: Maturecheese_imp
  DID ZVM_X Chains Houtman_imp 14 1,131 03-09-2021, 07:41 AM
  Steel Rear Sprockets johnnyj_imp 29 1,745 04-27-2020, 10:48 PM
Last Post: jimgl3_imp
  Chain and Sprockets - O My! Mandrau_imp 1 222 09-06-2019, 12:26 AM
  16 front 45 rear sprockets jermo47_imp 24 1,653 06-09-2019, 12:17 PM
Last Post: 17-CB-002
  DID silver plated ZVM-X chains Houtman_imp 44 2,969 12-12-2018, 11:16 AM
  Torque values for sprockets jermo47_imp 6 542 08-21-2017, 06:41 AM
