Riding the Brake Lever
My first bike was a used '71 Honda CB 350 and the brake pedal on it was level with the foot peg. There was no way to sit normally on it without accidentally applying the rear brake, so I got into the habit of turning my foot out slightly to avoid hitting the pedal, and I've done that ever since if the pedal is in the way. Cool
yep, I ride with mine "splayed" to avoid the levers too.
See my revision on post #1 for my latest attempt to avoid the brake lever.
I saw that WD...are you going to be able to even hit the rear brake pedal if you need it? That looks way high.
(04-14-2015, 06:53 AM)The ferret_imp Wrote: yep, I ride with mine "splayed" to avoid the levers too.
Not be be curmudgeonly, or worse yet, sanctimonious, but "splay" at your own peril!
Twice in the last five years, I have dropped a dirt bike in loose track on to its right-side and landed badly because of my "slightly splayed" boot. Slightly, as in maybe 15 degrees. In each case, as the bike fell slowly to the side (with me underneath)the splayed boot caused my foot to twist around with my torso facing forward and my foot point behind the bike. I was unable to move, in excruciating pain, and in excruciating pain. Serious pain! I couldn't do anything about it until someone lifted the bike off of me.
Lesson #1 NEVER SPLAY!! It is not taught anywhere that I know. It is not a "technique that MSF endorses, as far as I know. My remedy was to spend the time, effort and small amount of money to make my size 12s fit the bike better. The brake pedal has either been adjusted properly, or modified properly to make it work for me. I can now ride with my foot hovering just above the brake pedal in a very natural position. I have asked quite a trailing riders if my brake light comes on unexpectedly. They tell me it doesn't.
Of course, this probably doesn't mean anything to another person. Before you judge me, ride a mile in my shoes!
Riding on the street 50 years next month (way before MSF started endorsing anything), raced motocross for 10 years (was pretty good too.. but I still fell once in awhile and never landed with my foot facing one way and my torso the other). I think you just had some really bad luck. Appreciate your concern, but I think I'm ok.
[url=http://smg.photobucket.com/user/theferret111/media/CB%20ride%20April%2010%202015%20004_zps7aemh90y.jpg.html][Image: 4bafccd772482152cf79964a546b999f.jpg]
(04-14-2015, 07:11 AM)The ferret_imp Wrote: I saw that WD...are you going to be able to even hit the rear brake pedal if you need it? That looks way high.
Ferret. It probably is but I can reach the pedal. If I need to, I can remove one of the rubber blocks or (gasp!) raise the brake lever. Block removal may be problematic as I used Gorilla glue which is quite strong. But I can remove the whole thing and use a fresh block of rubber. The next single block would be the same height but more narrow, like the width of of the stock peg cover.
BTW. I ordered a NC Street Shield EX last night. Can't wait to receive it. Banana
Ferret wrote;
Good.
The difference between bad luck and good luck on a motorcycle is very expensive. I do everything I can to eliminate as a variable. It's never enough. Smile
(04-14-2015, 09:10 AM)Olyrider_imp Wrote: Ferret wrote;
Good.
I understand. Probably a good plan.
This thread could be bad for motorcycle sales all over the world.
If people start figuring out that you can get away with riding the brake pedal there's no way that they are going to fork over the money for the whole motorcycle. Just think of the ease of parking and how little storage space is needed. I could have a fleet of thousands in my garage. No telling which one I'll take for a spin tomorrow. Tongue
  Replace clutch Lever Davidjill_imp 10 971 02-06-2025, 01:27 AM
  Front brake lever ROCK hard ichiban_imp 37 3,836 02-10-2023, 10:54 PM
  Long shift lever Sam Mac_imp 1 266 02-08-2023, 08:30 AM
  Clutch Lever Full Engagement odelegacy_imp 41 2,688 10-28-2022, 09:27 PM
  Brake lever gap from throttle. zirconxi_imp 16 1,290 10-25-2020, 06:26 PM
  Bike fell over, broke the front brake lever and bent the rear brake jlouis976_imp 24 1,684 09-14-2018, 12:35 AM
  Front brake lever play Cormanus 8 502 06-26-2017, 06:49 PM
  Clutch Lever Replacement tavoeltav_imp 12 789 06-09-2017, 07:09 AM
Last Post: Outtabout_imp
  Front brake and brake light problem Krupator_imp 8 621 05-31-2016, 10:26 AM
Last Post: Ulvetanna_imp
  Shifter Lever Height Adjustment White Dog_imp 4 414 08-03-2015, 11:48 PM
Last Post: White Dog_imp
