Clutch Lever Replacement
Hi guys!
First off, I have terrible news... Only a month with my baby, and I dropped her already. Sad It was so embarrassing! I was simply turning her around to park, when the front wheel slipped on some wet leaves, and down she went...
The good news is the crash guards around the engine did a great job at keeping her from getting damaged! Bad news is they can only do so much... My clutch lever broke right in half! Now I can't ride around... I tried calling shops and my local dealer and an OEM lever runs $46.00. That's way too much for just a lever! Does anyone know where I can get some aftermarket ones that fit it? And does anyone know what I would be getting myself into by replacing it myself?
Thanks for any and all help!
If you know a TIG welder you could repair it quickly. At least that's what I did for my brake lever. I bought a replacement incase I encounter another parking issue. Jon Z
http://www.partzilla.com/parts/detail/ho...J-305.html
Oh, wow. Thank you for the fast response, guys! You guys rock! Big Grin
I would call the local dealer and see if he will price match the online price because if you can walk in and get it, so much the better because usually you will pay shipping from an online store.
And make sure to save the page on your phone so you can show him that it's a genuine Honda part because they will always question that.
Oh, and dealers usually have 3 pricing schedules......
jobber...to mechanics (they buy a lot of stuff)
retail....to somewhat regular customers (not so much)
and list.....screw you, you are the general public.
I used to work at a dealer and I always hated that they toasted the general public like that. Not all of them, but most of them do. And inn the power sports end of things...yeah...forget about getting a break if they think they can get away with it.
Replacing the lever is easy. Just pull the cable out as far as possible to get the barrel end into the slot on the lever.
Cable?
(10-14-2015, 07:49 PM)CB4ME_imp Wrote: Replacing the lever is easy. Just pull the cable out as far as possible to get the barrel end into the slot on the lever.
Boy, you really did get the retro model CB4ME. ROFL
Undo the nut, unscrew the screw, pull the lever out. Grease barrel and put barrel in new lever. Grease lever and perch. Stick new lever in making sure barrel and rod line up. Put screw back in, put nut back on.
http://cb1100forum.com/forum/showthread.php?tid=6755
You should look at some of the chinese pazzo knockoffs they sell on Amazon.
(10-14-2015, 10:50 PM)INTP_imp Wrote: You should look at some of the chinese pazzo knockoffs they sell on Amazon.
For the price difference I'd stick with the genuine part.
  CB1300 headlight bucket replacement spechg 5 389 03-16-2026, 10:12 AM
  HISS Key replacement UK Davidjill_imp 12 1,021 01-19-2026, 05:09 AM
  CLUTCH FLUID CHANGE SUPERCRUZ_imp 15 1,321 12-24-2025, 11:14 AM
  Rear brake pad replacement LongRanger_imp 39 3,739 05-03-2025, 10:45 AM
Last Post: Delphisa
  Replace clutch Lever Davidjill_imp 10 1,002 02-06-2025, 01:27 AM
  Clutch Plates finally going? misterprofessionality 12 1,084 11-22-2024, 07:49 AM
  Clutch fluid change CB1100@2013: photos valkyrie_rider_imp 0 250 02-13-2024, 10:27 AM
Last Post: valkyrie_rider_imp
  Fork Pipe replacement suggestions danieljrmurray_imp 3 516 10-09-2023, 02:31 AM
Last Post: danieljrmurray_imp
  Clutch Fluid Wagonpeddler_imp 32 2,588 06-14-2023, 08:09 AM
Last Post: bvictory_imp
