Oil Leak! Please help
(05-09-2015, 02:32 AM)Lord Popgun_imp Wrote: Don't forget to put sealant in the "semi-circular cut-outs" using Three Bond 5211C or equivalent. Manual shows it going at the top of each cutout (both sides) where the cover mates with the head. I'm sure you can see where by looking before you remove the cover.
If you have a manual, sorry for the above.
Good looking out!
My bike has a leak in the same area. Not sure if i should wait until i check the valves or try to fix it.
Let us know how you fix the problem. My area is exactly the same.
thanks
-Ish
(05-26-2015, 08:50 AM)ish_imp Wrote: My bike has a leak in the same area. Not sure if i should wait until i check the valves or try to fix it.
thanks
-Ish
Forgive me for butting in but I believe the fix was described on post #18.
Haven't figured out how to post photos yet, but my '14 DLX has a gob of clear silicone sealant at every joint between the cam cover and head at the 3:00 and 9:00 positions of all four round chrome end covers. The silicone looks bad up close and I've been meaning to try cleaning it up, but zero leaks so far. It's been there since new so Honda must have started doing it to address the oil leak problem some of you are having. It's not the type of oil you're using. I would just keep cleaning it until the cam cover has to be removed for your first valve check, then dab sealer in those areas before reinstalling the cam cover.
Actually the sealant is, or should be, on all the engines. Its on the US 2013s and is in the service manual which says use Three Bond 5211C or equivalent. I did post that above, and no, I don't know what Three Bond 5211C is. Smile
The stuff on my bike is not clear, but yellowish. Interesting there is a difference.
(05-26-2015, 12:12 PM)Lord Popgun_imp Wrote: Actually the sealant is, or should be, on all the engines. Its on the US 2013s and is in the service manual which says use Three Bond 5211C or equivalent. I did post that above, and no, I don't know what Three Bond 5211C is. Smile
I can't find it for sale in the US. I emailed the company to see if it is available here. This link shows it available in the UK.
http://www.techsil.co.uk/three-bond-tb52...lant-330ml
The sealant on my DLX looks and feels exactly like dried clear silicone sealant... I have no idea what the Three Bond stuff is either!!
Well, again Google is my friend. Apparently, Three Bond is a clear silicone sealant. Wonder why mine is yellowish?
Anyway here is a link to more than you will want to know about it: http://www.techsil.co.uk/three-bond-tb52...lant-330ml
Just tighten the bolt at the top of your picture. Solved my problem.
Sorry Xyzzy, I guess I didn't notice you posted the link that I did. Reading is fundamental Smile
  Slight Oil Leak DutchRutter 22 3,790 05-16-2025, 06:49 AM
  Oil Leak? bvictory_imp 0 200 06-14-2023, 07:05 AM
Last Post: bvictory_imp
  Just found a leak Gone in 60 20 1,320 06-17-2021, 10:18 AM
  slight oil leak Enzofour_imp 3 358 06-07-2021, 12:26 AM
Last Post: michael1954
  Oil Leak - Just got work done and then moved. NickyV_imp 34 2,213 10-15-2020, 02:13 PM
Last Post: max
  Cylinder Head cover oil leak and valve clearance increase. zirconxi_imp 6 608 09-01-2020, 12:19 AM
  Oil leak from pulser cover? skatamutra_imp 4 411 06-14-2020, 07:17 PM
   Oil leak! Help me! steed_boy_imp 43 3,639 02-09-2019, 12:22 AM
  Gas leak ? gaby_imp 15 1,039 04-14-2018, 09:29 AM
Last Post: Desert viper_imp
   Oil leak... Please help me.. Coldshot_imp 3 757 06-22-2016, 01:23 AM
Last Post: kmoney_imp
