Bike is starting to Irritate me re oil filter backing out
(02-22-2016, 07:14 AM)Lord Popgun_imp Wrote: You got it Mr. Ferret. The manual lists it as 19 ft. Lbs or 26Nm or 2.7Kgf m. And apply oil to threads and o-ring.
How do you get your iPad to not capitalize after a period? Like when you type ft. Lbs
After you type a period, popgun, the iPad automatically turns on the shift key. You have remember to turn it off if you want to start a new sentence or word with a lower case letter.
Jazzmans what a pic, but at least it must be comforting to know you can still install an oil filter!
Thanks Cormanus. Been driving me nuts. I was thinking it was something to do with the caps lock but that didn't work. Smile
For the caps lock you have to double tap the shift key. It goes dark and a little line appears underneath it.
https://goo.gl/photos/NnnRAobjCbxuBaY4A
Well, there you see it. on the top that tiny gap between the bolt flange and the filter itself is where the oil is leaking from. It leaked ~2/3ds of a quart (measured by amount it took to take back up to full, bike does not burn or leak oil normally.)
Soon as I started the bike with the K&N filter re-tightened, it started Drip, Drip, Drip, Drip,
I'm lucky I didn't die (oil on the tire) or blow up the motor. I had been planning on riding the CB back to death valley yesterday, but when this happened on sunday I knew that was out... Just think what would have happened in DV had I just tightened and riden....
p.s.
Love the Death Valley photo.
Just slap on some JB weld and got for it!!! Tongue
I use the WIX filters with great success.
(02-22-2016, 07:11 AM)EmptySea_imp Wrote: 13 ft lbs, Ferret. According to your post in the Torque Settings thread I linked to above.
Negatory Sea, Redbirds said 13 in that thread, I corrected him with the 19 figure.
Jazzman, according to k&N website it's supposed to be a 17 mm nut ( takes a 17mm wrench)
ferret, not mine, it was too small for a 17mm wrench, (wrench would just round it out if I tried) and a 16 wouldn't fit. I also tried with the appropriate SAE wrenches in that size range(what sizes escapes me at the moment) and it was the same, either it would just round out or it wouldn't fit at all.
The Honda filter says on it 26 Newton meters of force.
I'll just be happy when my driveway is paved again so I can test ride my bike.... Replacing the water main, so I had to roll the FZ out in front of the driveway where i could chain it up before they tore it all up or else wait til the new concrete gets poured and dries, which looks like a couple of days away still....
Glad to hear you found the culprit, Jazzman. I used to use K&N oil filters years ago, until I (and others) started having problems with the nut on the end breaking off. I went back to the Honda OEM filters with a cap type wrench. Fortunately, both of my bikes use the same filter so I buy 'em in bulk whenever I see a sale online.
  Oil Filter dave 12 558 07-26-2026, 02:33 PM
  Pod Air Filter Traumend_imp 15 1,496 03-06-2024, 08:42 AM
  K&N air filter fitment question nikolus_imp 28 3,656 05-20-2023, 09:26 AM
Last Post: Klamathonian_imp
  Fuel filter replacement Mafd2_imp 36 2,952 02-11-2023, 01:54 AM
  Oil filter won’t come off Jgarciajr40_imp 20 1,638 01-01-2023, 09:38 AM
   Oil Filter Options Yata-Garasu_imp 78 7,501 09-28-2022, 08:03 AM
Last Post: Yata-Garasu_imp
  Air filter options - W/ Part #'s PowerDubs_imp 10 938 09-21-2022, 04:02 AM
  Video: oil and filter change Scotty_imp 15 1,230 12-05-2021, 02:43 AM
  Air Filter Change Interval? dave 25 1,971 11-09-2021, 02:18 AM
Last Post: SportsterDoc
  Oil change - filter differences. Mixagon_imp 41 3,478 09-07-2021, 07:44 AM
