04-27-2016, 03:12 PM
Great info, Flynrider. Thanks!!
Drive chain replacement time, probably.
04-27-2016, 09:50 PM
So what is a better chain tool?
2014 CB1100 DLX 2013 CB1100 Std 1990 BMW K75 RT
04-28-2016, 05:31 AM
If you use a master link clip, the closed end of the clip goes in the direction of the chain. Crimping is better.
04-28-2016, 07:14 AM
Is this tool the same as the Stockton brand at Cycle Gear? It looks the same to me.
http://www.amazon.com/Goplus%C2%AE-Motor...rivet+tool
04-28-2016, 10:48 AM
(04-28-2016, 07:14 AM)kennyw_imp Wrote: Is this tool the same as the Stockton brand at Cycle Gear? It looks the same to me. Yep. That looks identical to the Stockton brand that I got at Cycle Gear. That looks like a pretty good deal on Amazon. Also explains why it seems to be perpetually "on sale" at Cycle Gear. ![]() Elipten : My old breaking/staking kit was a much more expensive Motion Pro (that managed to move to another state with my tool borrowing neighbor). As far as I can tell, it's about the same quality as the Stockton kit (and looks identical). For chain breaking, both kits recommend grinding the rivet head on chains larger than #520, due to the possibility of overstressing the breaking tool. I found that I could break a #525 and #530 by doing it slowly and carefully (I don't have a grinder handy).
04-28-2016, 12:36 PM
You can pick up a 4" angle grinder to get the job done for $15 at Harbor Freight
05-31-2016, 12:41 PM
(04-27-2016, 02:35 AM)Rolls_imp Wrote: For chain and sprockets replacement, are there any other miscellaneous parts I'll need, like new bolts, washers, seals or so forth? Is it a 110 link length? Did you get an answer to the number of links needed? I'd rather not go out and start counting...
05-31-2016, 01:22 PM
Per the Honda Service Manual:
110 links Replacement chain: 2013 model: DID: DID50ZVM2 RK: RK50LFOZ2 2014 model: DID: DID50VA11 RK: RK50HFOZ6
06-01-2016, 02:42 AM
Is this a pretty doable repair at home with the right tools? I've never messed with replacing a chain or sprockets. Most of my bikes have been shaft or belt drive...
06-01-2016, 02:48 AM
Well, you would need a chain breaker and a staking tool for the master link rivets. And hopefully a service manual for the proper staking of said rivets.
« Next Oldest | Next Newest »
| CB1300 headlight bucket replacement | spechg | 5 | 388 |
03-16-2026, 10:12 AM Last Post: Lord Popgun |
| HISS Key replacement UK | Davidjill_imp | 12 | 1,011 |
01-19-2026, 05:09 AM Last Post: Cormanus |
| Rear brake pad replacement | LongRanger_imp | 39 | 3,656 |
05-03-2025, 10:45 AM Last Post: Delphisa |
| New speed meter replacement | ACE_IRA_imp | 3 | 529 |
02-13-2025, 06:25 AM Last Post: Lord Popgun |
| Fork Pipe replacement suggestions | danieljrmurray_imp | 3 | 514 |
10-09-2023, 02:31 AM Last Post: danieljrmurray_imp |
| Fuel filter replacement | Mafd2_imp | 36 | 2,937 |
02-11-2023, 01:54 AM Last Post: GoldOxide_imp |
| Replacement Battery | dave | 54 | 4,174 |
02-04-2023, 12:41 PM Last Post: GoldOxide_imp |
| Front drive chain sprocket wear | 1970Cadillac_imp | 15 | 1,255 |
11-29-2022, 07:49 AM Last Post: dave |
| 2013 replacement wheel | Randy B | 8 | 797 |
11-13-2022, 10:32 AM Last Post: Randy B |
| Clutch replacement advice | misterprofessionality | 31 | 2,555 |
06-11-2022, 05:51 PM Last Post: Cormanus |
