Spark Plugs
(06-12-2015, 03:51 AM)The ferret_imp Wrote: The CB 1100 takes special one off spark plugs designed for this bike. made by NGK they carry the designation LMAR8A-9S Honda part number 31908-MGC-003 and takes QTY 4. The bodies on these plugs are extremely thin as are the threads which are also extremely long at 26.5 MM or just over an inch.
The plugs are expensive at $19.99 each and it's highly unlikely your dealer will stock any so they will probably need to be ordered. A standard spark plug wrench is not going to work well given the small confines of the area to work in. However Motion Pro makes a thin walled 14MM narrow plug wrench that uses a 1/4" ratchet, a 13 mm box end wrench or a 14 mm box end wrench socket or T handle to loosen and tighten. It also has a rubber ceramic gripper up inside. Your dealer can get this from one of his suppliers or you can order it directly from Motion Pro
This pic illustrates just how small these plugs and tool are, On the left is a standard spark plug socket next to the Motion Pro Unit.
On the right is a standard spark plug next to the plug used in the CB 1100. Gap .031-.035 using a wire type feeler gauge is recommended.
L to R std spark plug socket, thin walled 14 mm Motion Pro spark plug socket, std spark plug, LMAR8A-9S spark plug for CB 1100
[url=http://smg.photobucket.com/user/theferret111/media/image.jpg1_zpsakibhpti.jpg.html][Image: 4d7a40dc1fd4cc5ac74982ea25fcff03.jpg]
It took a little over a week for a large Honda dealer in Houston to order and receive my replacement spark plugs. And Ferret spot on, I believe they were about 19 bucks a piece. Plus install costs . . . .
I pulled my plugs @ 5000 miles to inspect. No re gaping no cleaning they were fine. Anti seize on the threads and back in. I will pull again @ 12000 miles.
(06-13-2015, 12:38 AM)Ole_imp Wrote: I pulled my plugs @ 5000 miles to inspect. No re gaping no cleaning they were fine. Anti seize on the threads and back in. I will pull again @ 12000 miles.
FWIW: http://www.ngksparkplugs.com/pdf/dyk_5points.pdf
Quote:NGK spark plugs feature what is known as Trivalent plating. This silver or chrome colored finish on the threads is designed to provide corrosion resistance against moisture and chemicals. This coating also acts as a release agent during spark plug removal. NGK spark plugs are installed at the factory dry, without the use of anti-seize. NGK tech support has received a number of tech calls from installers whom have over-tightened spark plugs because of the use of anti-seize. Anti-seize compound can act as a lubricant altering torque values up to 20 percent, increasing the risk of spark plug thread breakage.
Wow, that's interesting
I change out quite a few plugs each year and never use anti seize, plus don't bother torquing the plug if you use it, you will not get a proper reading.
What's the best way to get to the inner plugs? I've got the slim socket...
Sent from me......
(05-21-2016, 05:08 AM)MMC_imp Wrote: What's the best way to get to the inner plugs? I've got the slim socket...
Sent from me......
1/2" drive ratchet and 1/2 to 3/8 adapter should put you below the frame and over the valve cover.
Use the factory socket.
Thanks for posting this. I thought I had all the spark plug sockets I needed. Glad Father's Day is coming.
Toro..do you have the one in post 1 of this thread? You can use a 13 mm box end wrench, 14 mm box end wrench or 1/4" drive ratchet I believe
  NGK spark plug options Jonnyteabag_imp 6 615 08-05-2026, 11:35 PM
Last Post: JRD
  spark plugs after 70.000 Km DAC 16 1,505 12-23-2025, 10:15 AM
  'Factory' high performance spark plugs PowerDubs_imp 17 1,471 10-23-2024, 02:50 PM
Last Post: rtmoto1
  Spark plug socket. Jgarciajr40_imp 5 557 09-11-2023, 10:40 PM
Last Post: Jgarciajr40_imp
  spark plugs NGK LMAR8A-9S louied_imp 1 327 06-27-2023, 01:19 PM
  2017 CB1100EX Accessory Plugs TXBikerGuy 13 1,127 06-24-2023, 08:27 AM
  spark plug caps alexzanutto_imp 3 394 01-29-2023, 06:21 AM
Last Post: artashline_imp
  spark plug help, please !! The Gecko_imp 10 774 10-08-2022, 12:22 PM
  Spark Plugs HondaJon_imp 105 6,995 03-19-2022, 08:53 AM
  CB 900C Custom Spark Issue goatman64_imp 3 361 11-27-2021, 07:11 AM
