Chain replacement
Yes if it is a rivet link. But you can get a tool really cheap. Or spend semi big bucks for a more pro tool.
(07-10-2018, 09:19 AM)MMC_imp Wrote: So I ordered a DID Xring chain. It’s says “Master Link(s) Included with chain: Rivet”
Does that mean I have to get a tool to install the master link?
Not necessarily although that will make it easier. I installed one on my Yamaha FZ-1 using a steel plate for a back plate and a hammer and punch to flatten the rivet.
There are videos on you tube showing the process.
Ok, thanks. I haven’t replaced a chain in years, my last two bikes have been shaft drive and before that they were all master link with clip, back when.
I would not be aftaid to run a clip link still, but then I ride like a grandfather. Wait... I am a grandfather (x5. The oldest in college) lol
(07-10-2018, 11:07 AM)The ferret_imp Wrote: I would not be aftaid to run a clip link still, but then I ride like a grandfather. Wait... I am a grandfather (x5. The oldest in college) lol
I’m a grandpa too (1x) but, 90 miles a day in and out of traffic, I don’t think I’ll rely on a clip. [Image: 595f1eee1859abb2c0bd652cd5f9ea3c.png]
I used to use clip master links almost exclusively, until the last time I went to change the worn out chain on the CB750. I spun the tire to locate the master link and found the master link, but the clip was missing. I have no idea how long I'd been riding like that. After that I decided to make the investment in a decent chain tool and used riveted master links.
I have never seen a clip put on properly come off, but I suppose it has happened. My nephew used E clips on one of his bikes saying you might lose 1 but chances are you will never lose both, with makes a lot of sense.
The spec for riveting a master link is pretty technical. Measure the plate front and back to make sure it's straight, then mushroom and measure the head of the squished rivet. Squish it too hard and you are in the dog house as their is no way to un-squish it. I let the shop do the replacement on my CB1100 a few months ago, but I am never confident in their ability to do it right, but even less confident in MY ability to do it right lol.
(07-11-2018, 04:59 AM)The ferret_imp Wrote: I have never seen a clip put on properly come off, but I suppose it has happened. My nephew used E clips on one of his bikes saying you might lose 1 but chances are you will never lose both, with makes a lot of sense.
I agree with you Ferret. In 48 years of riding, I have never seen a clip link come off, nor heard of any of my riding buddys having one come off. That said, we used to carry a spare master link and clip wrapped in plastic in the tool kit under the seat. I like your Nephews idea, but I think I would be more inclined to try a couple of snap rings put on with snap ring pliers, because that type ring would encompass the full diameter of the link pins. I am wondering if the switch to riveted links may have an effort to avoid liability issues? Because, as we all know, someone will always do a simple install like a clip link improperly, resulting in an unnecessary failure of the part. Being able to take a chain off because it had a clip link, to give it a cleaning bath, would certainly be a lot less messy, and a lot easier IMHO.
I hadn't either. I've been installing them since 1980 and always triple check that the clip is properly seated.
Back then I didn't used to clean my chain much and the accumulated gunk made it hard to easily see the clip was missing.
Installing the rivet link is an exercise in patience. I squeeze it with the tool a bit, then remove it and measure with a caliper. As I recall, it took me about 7 or 8 repetitions to get it just right.
So I got the chain on. No problems. I got 43,500 miles on the original chain and probably could have adjusted it at least once more. I didn’t realize that the original was a DID x-ring chain! Guess I’ll get another 43,000 or so on my new one too. [Image: e724ee7a64682a6db2bf1ca18157d62d.png]
  CB1300 headlight bucket replacement spechg 5 359 03-16-2026, 10:12 AM
  HISS Key replacement UK Davidjill_imp 12 891 01-19-2026, 05:09 AM
  Rear brake pad replacement LongRanger_imp 39 3,406 05-03-2025, 10:45 AM
Last Post: Delphisa
  New speed meter replacement ACE_IRA_imp 3 515 02-13-2025, 06:25 AM
  Fork Pipe replacement suggestions danieljrmurray_imp 3 471 10-09-2023, 02:31 AM
Last Post: danieljrmurray_imp
  Fuel filter replacement Mafd2_imp 36 2,797 02-11-2023, 01:54 AM
  Replacement Battery dave 54 3,755 02-04-2023, 12:41 PM
  2013 replacement wheel Randy B 8 755 11-13-2022, 10:32 AM
Last Post: Randy B
  Clutch replacement advice misterprofessionality 31 2,381 06-11-2022, 05:51 PM
  Throttle cable replacement Stoked907_imp 1 266 05-20-2022, 09:35 AM
