06-25-2018, 04:21 AM
What chain is good to use? I can’t seem to find any discussion on it.
Chain replacement
06-25-2018, 04:45 AM
Is this the start of a... chain thread?
I've not needed to replace mine yet, but if you've been satisfied with your OE chain, why not just replace it with another one? I imagine they're available in the aftermarket at a lower price than Honda charges.
06-25-2018, 04:53 AM
I got 36,909 miles out of my oem chain so I replaced it with another oem. Mine was an RK and so was it's replacement. An oem DID is available too.
06-25-2018, 05:08 AM
06-25-2018, 05:10 AM
yes on all counts.... also replaced the rubber drive cushions
06-25-2018, 05:26 AM
(06-25-2018, 04:45 AM)LongRanger_imp Wrote: Is this the start of a... chain thread? “Is this the start of a... chain thread?” Lol I’ve got over 43,000 on my bike, time to replace the chain. I’ll probably go with an aftermarket one. The sprockets actually look fine but chain is stretched. I’m just checking to see if anyone has recommendations for one to use. Sent from my iPhone using Tapatalk
06-25-2018, 05:50 AM
IMO you can't beat a DID X ring chain for a replacement.
I know i know, I used an RK oem, but I have used DID X rings in the past and they are great chains.
06-25-2018, 06:35 AM
Thanks for the responses.
06-25-2018, 06:49 AM
(06-25-2018, 05:50 AM)The ferret_imp Wrote: IMO you can't beat a DID X ring chain for a replacement. +1 My OEM chain still looks good at 24K miles, but every time I've needed to replace a chain on one of my bikes, I've always used a DID X-ring or O-ring. Never had a problem and they've always lasted longer than expected. Last one I replaced on the CB750 was a DID VX Series X-ring chain. At 25K miles, it's hardly worn at all.
06-25-2018, 09:29 AM
DID X-ring came stock on my 2012 Bonneville.
It required one adjustment, when new. Never touched it again until ~7,000 miles/one year, when the bike got its first coin-op wash after a trip to my ranch (16 miles of rough dirt road/trail). I then used a wax based lube. |
« Next Oldest | Next Newest »
| CB1300 headlight bucket replacement | spechg | 5 | 359 |
03-16-2026, 10:12 AM Last Post: Lord Popgun |
| HISS Key replacement UK | Davidjill_imp | 12 | 891 |
01-19-2026, 05:09 AM Last Post: Cormanus |
| Rear brake pad replacement | LongRanger_imp | 39 | 3,406 |
05-03-2025, 10:45 AM Last Post: Delphisa |
| New speed meter replacement | ACE_IRA_imp | 3 | 515 |
02-13-2025, 06:25 AM Last Post: Lord Popgun |
| Fork Pipe replacement suggestions | danieljrmurray_imp | 3 | 471 |
10-09-2023, 02:31 AM Last Post: danieljrmurray_imp |
| Fuel filter replacement | Mafd2_imp | 36 | 2,797 |
02-11-2023, 01:54 AM Last Post: GoldOxide_imp |
| Replacement Battery | dave | 54 | 3,755 |
02-04-2023, 12:41 PM Last Post: GoldOxide_imp |
| 2013 replacement wheel | Randy B | 8 | 755 |
11-13-2022, 10:32 AM Last Post: Randy B |
| Clutch replacement advice | misterprofessionality | 31 | 2,381 |
06-11-2022, 05:51 PM Last Post: Cormanus |
| Throttle cable replacement | Stoked907_imp | 1 | 266 |
05-20-2022, 09:35 AM Last Post: peterbaron |
