Real world benefits of the slipper assist clutch
(01-21-2018, 09:26 AM)PowerDubs_imp Wrote: I must be old- I think the stock clutch is very light as compared to old school mechanical cable clutches..
Yep, can even pull it back to the grip with one finger.
Can even do it with little finger (bit awkward).
(01-21-2018, 02:21 AM)jedd_imp Wrote: Well, on my way to costco, I went to check out that '17 EX at my dealer's showroom yesterday.
At first I couldn't find it in its former spot on the showroom. The sales mgr went freakin' hog wild and restocked the showroom like they won the lottery.... wall to wall, full of bikes and ATVs,
couldn't even walk in some places to get close to the bikes.
But I found it parked next to the parts counter.
First thing I noticed is, sticker price now says $10,400!
2nd thing....clutch pull is truly a 1 finger pull - and I can hold it in w/ my index finger for 1 min.- no probs.
I'm AMAZED at how light it is to pull that sweet hydro cluch.
This should make my gridlock crawling situations all the more better.
I'm sold, so I'm going to do it.
Wow! I'm keeping my eyes out for a '17 at a big discount.
Honda say 17 percent lighter clutch pull. It wasn't too stiff to begin with.
Are the master and slave cylinders the same part number? I wonder that the ratios could be change to deal with the lighter springs.
YES the part number is identical for all yrs.
PISTON SET, MASTER CYLINDER
22886-MAT-E01
Like stated in OP, I don't have a problem w/ the stock pull, but from riding dirt and trials bikes for so many years,
I have come to appreciate doing all my clutch work using just my index finger.
One finger pull could be done on the stock one, but to hold it in for some time w/ 1 finger while waiting for the green light or for gridlock to inch its way up...that does take some effort. I'm really not trying to sell anyone on doing this. I'm just grateful that Honda came out with this on their '17, and I can buy all the parts to do this. This will only make me want to keep my '14 that much longer.
(01-22-2018, 04:44 AM)jedd_imp Wrote: YES the part number is identical for all yrs.
22886-MAT-E01
Me too. One or two. For roadwork, usually two. Quick shifting sort of demands that technique. Same with the brakes.
But the lighter clutch pull's good for any rider, and the slipper feature is actually the big benefit, for safety.
If a guy can do the work himself, for that amount of money, I'd say go for it, it's a big upgrade.
Has anyone successfully completed this upgrade?
I attempted this project, however the new clutch center appears to be too short for the shaft. There is extra room between the nut and the clutch center. Any input is appreciated.
Welcome aboard upsdoc. I don't recall hearing that anyone has completed this. But I've been wrong before.
Pics of what you are seeing and the part #’s you used please.
I am out right now, but if you can get us that- when I get home I will double check everything for you.
I replaced all clutch parts (#4 to #22) except the clutch outer (#1,2 and 3), which is the same on all years.
I will reinstall the 2017 clutch parts tomorrow and take pictures.
Thanks in advance for the help.
for something you can adjust the lever.....but bcos only the pullpower extra change the clutch ..well i dooooont know........and so long you havent a healtproblem with your hand: muscle-training ?
the power from the 14 model clutchlever is not realy strong too......the hardest ever was for me that switch on an HD...my god...
Here is a picture comparing the clutch center of the 2014 model vs the 2017.
2014 is on the left. As you can see the clutch is taller, due to the damper assembly on the 2014.
You can see the excess space on the shaft with the 2017 clutch center.
  CLUTCH FLUID CHANGE SUPERCRUZ_imp 15 1,175 12-24-2025, 11:14 AM
  Replace clutch Lever Davidjill_imp 10 930 02-06-2025, 01:27 AM
  Clutch Plates finally going? misterprofessionality 12 1,032 11-22-2024, 07:49 AM
  Clutch fluid change CB1100@2013: photos valkyrie_rider_imp 0 234 02-13-2024, 10:27 AM
Last Post: valkyrie_rider_imp
  Clutch Fluid Wagonpeddler_imp 32 2,413 06-14-2023, 08:09 AM
Last Post: bvictory_imp
  Clutch Not Working Henrik_imp 7 613 04-24-2023, 06:43 PM
Last Post: Henrik_imp
  Clutch pull mpuhl_imp 4 483 02-21-2023, 10:48 AM
  Clutch slave cylinder gasket Maturecheese_imp 3 366 01-27-2023, 12:33 AM
Last Post: Maturecheese_imp
  brake & clutch adjusters The Gecko_imp 10 768 11-25-2022, 08:47 AM
  Clutch Lever Full Engagement odelegacy_imp 41 2,649 10-28-2022, 09:27 PM
