IACV Replacement Tips
(11-12-2018, 09:45 PM)snackie_imp Wrote: Hi Dave,
Just wondering if my description of the problem is similar to what you experienced? How many miles did you have on your bike when the problem occurred and how many miles have you put on the bike since you replaced the IACV?
Thank you!
Hello snackie. I didn't see a detailed description of the problem you are experiencing in this thread, did I miss something? I'm guessing here, but I think my bike had about 10k miles on it when the high idle / low idle / stalling symptoms began. For a more-accurate description of these symptoms please see the other threads on this subject. My symptoms came and went, and they varied between high RPM idle to low RPM idle, to stalling. I now have 3k miles on my bike since replacing the IACV and it is running perfectly.
Hi Dave,
We're you getting a check engine light (DTC code)? I only have the high idle problem, no stalling or low idle yet.
Thanks again,
Snackie
(11-28-2018, 05:32 AM)snackie_imp Wrote: Hi Dave,
Thanks again,
Snackie
Hi Snackie, no check engine light warnings, ever.
  CB1300 headlight bucket replacement spechg 5 386 03-16-2026, 10:12 AM
  HISS Key replacement UK Davidjill_imp 12 1,002 01-19-2026, 05:09 AM
  Rear brake pad replacement LongRanger_imp 39 3,641 05-03-2025, 10:45 AM
Last Post: Delphisa
  New speed meter replacement ACE_IRA_imp 3 526 02-13-2025, 06:25 AM
  New members tips max 54 4,480 10-29-2023, 12:11 AM
  Fork Pipe replacement suggestions danieljrmurray_imp 3 509 10-09-2023, 02:31 AM
Last Post: danieljrmurray_imp
  Fuel filter replacement Mafd2_imp 36 2,912 02-11-2023, 01:54 AM
  Replacement Battery dave 54 4,105 02-04-2023, 12:41 PM
  2013 replacement wheel Randy B 8 788 11-13-2022, 10:32 AM
Last Post: Randy B
  Clutch replacement advice misterprofessionality 31 2,513 06-11-2022, 05:51 PM
