IACV Replacement Tips
Has anyone personally replaced the IACV on there CB1100? If so, any tips?
For instance, does the throttle body have to be taken out to do the job?
Thanks,
Bryan
Yes, Dave + ?? ,backed by technical assistance by few forum members:
http://cb1100forum.com/forum/showthread....light=IACV
http://cb1100forum.com/forum/showthread.php?tid=12203
http://cb1100forum.com/forum/showthread....luctuation
http://cb1100forum.com/forum/showthread.php?tid=9117
+ few more. Use search to find out more
Have fun Smile
P.s Do you want just replacement or diagnose your problem first, two different things.
Study before digging.
Peter,
Thank you so much. Looks like there's plenty of tips in those threads and, yes, I will do my best to troubleshoot the IACV before ripping the bike apart.
Best regards,
Bryan
(11-08-2018, 10:46 AM)snackie_imp Wrote: Peter,
Best regards,
Bryan
No problem, this forum provides a lot of info, just to mention few names about this particular topic; Dave, Max, popgun, SportsterDoc + few more.... as said: study before working and good luck Thumbs Up
As he said, do study first. Its not an easy or quick job to get to the IACV.
First step in the manual: Disassemble rear half of motorcycle Wink
If my memory is good, there was Max??? post of faster approach by using modified Allen key ( but I am not 100% sure), so check it firstSmile
Yeah, we did go through that and it doesn’t work. You can’t get to it without removing the TB and that is a J.O.B.
OK, thanksSmile
Bryan none of us have the issue ourselves so we have to make best guesses but we learned a lot through Dave who did fix his iacv. there are two other members who have had success with this repair, it seems to only affect some 2014 models ( with some exeptions ) and we don't know why.
The iacv is a motorized air valve that regulates the amount of air to maintain 1050 rpm at idle, very much like opening the throttle slightly, it replaces the old school idle adjust screw and combines with the choke function and makes it automatic, it gets " stuck " at some point and gets worse over time.
Popgun is right, i thought i had found a shortcut but i was wrong, it did not work unfortunately.
The throttle body can stay where it is but the airbox needs to be removed towards the back so the tank, batterybox, rear fender etc have to be removed to gain access to the iacv which you need before all this is done, take lots of pictures so you know how things looked prior to removal.
Something that may work for you is disconnecting it when the bike behaves, is warmed up and idles at 1050 rpm, the piston inside will then stay open and doesn't move so the idle rpm stays around 1050 when warmed up, you need to remove the right hand plastic throttle body cover with the plastic screw and tilt it down to get access to the blue 4 pole connector, you squeeze the tab in the middle to unlock it and pull it out whilst the bike idles at 1050 rpm.
However you will get an orange check engine light blinking indicating a defect iacv code and may have to open the throttle a bit to get the engine to start initially but that may work ok in Hawaii because of the warm climate.
The c.e.l. light will stop when the connector is re-connected but the code remains in the memory and not visible unless it is in "service mode" and can then be erased by a sequence of the red service connector electrical wire link.
here is how to do this; https://youtu.be/iwSllBQNsWc
max, do you need the special bit of wire with a resistor or will any bit of wire work?
  CB1300 headlight bucket replacement spechg 5 400 03-16-2026, 10:12 AM
  HISS Key replacement UK Davidjill_imp 12 1,037 01-19-2026, 05:09 AM
  Rear brake pad replacement LongRanger_imp 39 3,921 05-03-2025, 10:45 AM
Last Post: Delphisa
  New members tips max 54 4,678 10-29-2023, 12:11 AM
  Fork Pipe replacement suggestions danieljrmurray_imp 3 523 10-09-2023, 02:31 AM
Last Post: danieljrmurray_imp
  Fuel filter replacement Mafd2_imp 36 2,972 02-11-2023, 01:54 AM
  Replacement Battery dave 54 4,469 02-04-2023, 12:41 PM
  2013 replacement wheel Randy B 8 829 11-13-2022, 10:32 AM
Last Post: Randy B
  Clutch replacement advice misterprofessionality 31 2,678 06-11-2022, 05:51 PM
