Engine dies when I put in 1st gear (yes, clutch is engaged)
On the wiring diagram the switch is shown (and labeled even)
Kickstand UP shorts the wires together
Down, opens the wires. Or disconnects them from each other for you non-tech types Smile
So to bypass or test the switch problem, just connect the 2 wires together somehow. Like with a jumper.
The connections could be dirty or corroded. I have read that on some bikes, going over bumps could cause the kickstand to jostle and break the connection. Make sure your kickstand is returning to the full up position and that the spring is tensioned ok.
I assume the bike is under warranty with that low mileage. Take it to your dealer and have them repair or replace the switch.
(08-24-2015, 09:27 AM)redbirds_imp Wrote: I assume the bike is under warranty with that low mileage. Take it to your dealer and have them repair or replace the switch.
Called dealer they told me that if it continues to happen to take it in. I'll do a visual inspection this week. I will probably permanently connect the two wires together.
Thanks for the input everybody.
Keep in mind that COULD effect your warranty because it changes the operation of the motorcycle.
The next time it happens take it to the dealer and if they give you the run around again tell them it's a safety issue and tell them it happened while you were in the far left lane of an interstate and you were almost run down and don't know how you survived and you also told your S/O and your attorney to sue the sh*t out of the dealer if you get injured or killed.
Don't do that! Get it fixed. I'm with Redbirds on this.
Don't do that! Get it fixed. I'm with Redbirds on this. It is a safety issue.
Me, too, aschem. If that's not the problem, you may void your warranty and the dealer then won't help you track it down and fix it.
Best wishes.
OK, very good points; I won't modify it, and I'll revert to my old NCO Infantry ways of dealing with the shop.
Hey guys, just had my bike quit after breakfast at the local diner. Managed to get it home. Checked the entire bike over and couldn't find any problems.
I hopped on the google machine and this thread came up. I went out to the bike, cycled the side stand a few times and she fired up and went into gear no problem.
Thanks for the tech help!
-Chun Rider
Welcome to the forum, Chun Rider.
  CLUTCH FLUID CHANGE SUPERCRUZ_imp 15 1,314 12-24-2025, 11:14 AM
  Replace clutch Lever Davidjill_imp 10 1,002 02-06-2025, 01:27 AM
  Clutch Plates finally going? misterprofessionality 12 1,084 11-22-2024, 07:49 AM
  Clutch fluid change CB1100@2013: photos valkyrie_rider_imp 0 250 02-13-2024, 10:27 AM
Last Post: valkyrie_rider_imp
  Clutch Fluid Wagonpeddler_imp 32 2,576 06-14-2023, 08:09 AM
Last Post: bvictory_imp
  Clutch Not Working Henrik_imp 7 659 04-24-2023, 06:43 PM
Last Post: Henrik_imp
  Clutch pull mpuhl_imp 4 519 02-21-2023, 10:48 AM
  Clutch slave cylinder gasket Maturecheese_imp 3 399 01-27-2023, 12:33 AM
Last Post: Maturecheese_imp
  brake & clutch adjusters The Gecko_imp 10 874 11-25-2022, 08:47 AM
  Clutch Lever Full Engagement odelegacy_imp 41 2,705 10-28-2022, 09:27 PM
