16 front 45 rear sprockets
Own a 2017 EX
Want to try a 16/42 set up which should give me close to 12% ~ 15% ratio change.
Plus I want to keep the original 530 chain.
Note: I barely use the 6th gear during my rides (now 13,000 Kms).
Just ordered a 42 Tooth rear sprocket (JTR #302.42).
Anyone has the front sprocket number for a 16T or 17T? (2017 EX)
Much obliged.
Alain
(06-03-2019, 01:10 PM)Alain Lee_imp Wrote: Own a 2017 EX
Much obliged.
Alain
2002-2013 VFR800 uses a 16-tooth that will fit - P/N 23801-MCW-D00.
All CBR1000XX Blackbirds use a 17-tooth that will fit - P/N 23801-MAT-760.
Factory sprockets have rubber dampeners on the sides for quietening.
Or you can order a JT sprocket, JTF339RB-16 or JTB339RB-17 with rubber dampeners, JTF339-16 and JTF339-17 without the dampeners.
Good luck!
I have the 16 on the front and still using the 43 on the back. Feels about 6% difference from the 17 on the front, which is about what it should be. I also installed my more upright bars (from the clipons i had on there) and have been enjoying the more upright seating position, but i have noticed that the front end does want to come up a bit more with the 16/43 setup, as expected. Nothing crazy or hard to deal with.
This is the 16 i used: JT Sprockets JTF339.16 16T Steel Front Sprocket
[url=https://www.amazon.com/gp/product/B000GTZ15O/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1]https://www.amazon.com/gp/product/B000GT...UTF8&psc=1
I had the 17 on there for about 15,000 miles and it looked essentially brand new when i took it off. Chain and rear sprockets looking good still at mid 17xxx miles. Overall Id say the 16/43 setup is just fine for the 2014s.
Thanks for the part number.
What a difference with the 42T modification!
You can feel lots of power on demand and the rpm is always above 3K.
First time ever, I was able to use the 6th gear and still feel the torque.
Very peppy bike when riding in town.
Only disappointment is the handle bar vibration felt at these higher revs.
Both hands felt numb after riding for half an hour.
I will wait a while before getting the front 16T.
  Center stand and new chain / sprockets jermo47_imp 8 879 04-24-2024, 10:55 PM
Last Post: jermo47_imp
  Rear only tire on the front? mattmcuomo@yahoo.com 5 592 10-09-2023, 06:05 AM
  Milage when replacing chain and sprockets Frulk_imp 8 637 02-11-2023, 03:29 PM
Last Post: Frulk_imp
  How To :19 tooth front, and now, a 37 tooth rear sprocket on 2013 pekingduck 60 4,122 03-07-2021, 09:32 PM
  Steel Rear Sprockets johnnyj_imp 29 1,826 04-27-2020, 10:48 PM
Last Post: jimgl3_imp
  Chain and Sprockets - O My! Mandrau_imp 1 230 09-06-2019, 12:26 AM
  Bike fell over, broke the front brake lever and bent the rear brake jlouis976_imp 24 1,690 09-14-2018, 12:35 AM
  Deciding 37 vs 35 tooth rear sprocket on 2013, 19 on Front is correct rbike_imp 41 2,808 09-01-2018, 03:19 AM
Last Post: IndianRider_imp
  New Rear Tire and Rear Brake Pads memphismike_imp 5 553 06-11-2018, 09:35 PM
  Torque values for sprockets jermo47_imp 6 570 08-21-2017, 06:41 AM
