Mandatory Tools for Road Trip (2017 model and later)
(07-22-2020, 06:34 AM)Alain Lee_imp Wrote:
(07-22-2020, 05:59 AM)peterbaron_imp Wrote: Some of you are planning on the road - major overhauling..Tongue
Big Grin
Hi Peter, have you ever been on the Manitoulin island (across from Tobermory?
I understand it is a stay over trip.
Regards
Alain
BTW, I am also planning to replace the piston rings with the engine running Big Grin
ROFL Now there is a mechanic!
Big Grin
Regards
Alain
WRONG!!, with THAT skills, you are called a tech!! Excited
You have to be very quick to change the piston rings while the engine is running but it can be done....
(07-22-2020, 08:17 AM)Houtman_imp Wrote: You have to be very quick to change the piston rings while the engine is running but it can be done....
Right, but after min 6 beers consumed Beer
NGK LMAR8A-9S (stock 6817) spark plugs are available from O’reilly’s for $5.99 each.
Are you sure they have the suffix S? The S stands for special washer, which were specifically designed for the CB 1100
Yep
6817 has the s suffix
[url=https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.ngk.com/product.aspx%3Fzpid%3D41476&ved=2ahUKEwjyxrbCjOLqAhWgHDQIHbG2CrsQFjAAegQIBxAB&usg=AOvVaw3Tzb7EteAXA3Mnw7HaHMrf]https://www.google.com/url?sa=t&source=w...Mnw7HaHMrf
That's a great price. I got some for that price mail order at the beginning of the forum, but they failed to have the S suffix. I have a thread on it here someplace, but pics are probably long gone
Original spark plug thread
http://cb1100forum.com/forum/showthread....hlight=NGK
Spark plug changing "how to" thread
http://cb1100forum.com/forum/showthread.php?tid=9674
(07-22-2020, 05:55 AM)pekingduck_imp Wrote:
(07-22-2020, 03:09 AM)Alain Lee_imp Wrote:
(07-22-2020, 02:59 AM)pekingduck_imp Wrote: Do you think the 17mm Allen is needed since the left side of the axle is pinched in the fork leg? At home, I use the 17mm Allen equivalent, but I don't carry it with me.
As far as breaking the bead on the rim, no hand tools could do that. There are compact bead breakers that off-road guys carry, but they are heavy and bulky. Besides, by changing to tubeless and carrying a plug kit and a compressor, I think you've done as much as you reasonably can.
You've probably eliminated 98% of the probability of need of taking the tire off.
I also carry a spare oil filler cap (in my bag of fuses) and a folding funnel.
Hi Pekingduck, since I have room for it, I included it in there - Yes, you are correct, the 2 pinch bolt should do the job.
As for breaking the tire, I prepared for the worst condition and hope for the best .
For severe puncture (big hole?) I have also included a tire patch that is done from inside the tire.
Can you explain about the filler cap and funnel logic. thanks
The filler cap is just a spare. I've heard of filler caps going mysteriously missing on parked bikes, and the amount of oil that gets sprayed up by the clutch will make an un-rideable mess quickly. Not likely to ever need it, but cheap insurance. (The BMW GS guys have accessory locking filler caps - you know who you are!).
And the funnel just because it's flat and is stored with the owner's manual.
Hi Pekingduck, After reading your comments, I went back to the bike and use a "Channel lock" (water pump) plier to tighten the filler cap (mine is a metal one with a built-in temperature gauge) - Just In Case Thanks
Does this mean you now have to carry the water pump pliers with you? Dodgy
  OBD Tools Davidjill_imp 9 840 11-16-2024, 02:00 AM
Last Post: Whoops
  Cam chain model and relpacement. syncronizator_imp 19 1,769 10-20-2023, 08:45 PM
  Tools you'll need the Ferret 109 9,337 03-23-2023, 11:04 PM
  What is the Correct Chain Size for a 2014 Model? chync_imp 12 1,166 02-28-2023, 01:16 AM
Last Post: Maturecheese_imp
  Tools Explained... Bazbro_imp 12 914 11-19-2021, 03:26 AM
  2010 model Power Commander alternative? 83NZA_imp 7 639 08-03-2021, 02:04 PM
Last Post: Aussieflyer
  Parts interchangability on US model years '13/'14 vs. '17? Whoops 7 708 04-13-2021, 12:05 PM
  Tools dave 22 1,585 03-17-2021, 01:56 AM
  Rust/corrosion - 2015 EX model N4RN_imp 7 688 10-26-2020, 08:25 PM
Last Post: syncronizator_imp
  Fuel tank interchangeability? Model difference questions.... 2014ltdltz 5 729 10-12-2020, 11:59 PM
Last Post: 2014ltdltz
