Tools Explained...
An oldie, but worth another airing...! Big Grin
DRILL PRESS : A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL : Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, 'Oh sh*t'
DROP SAW : A portable cutting tool used to make studs too short.
PLIERS : Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER : An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW : One of a family of cutting tools built on the Ouija board principle... It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
MOLE-GRIPS : Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH : Used almost entirely for lighting on fire various flammable objects in your shop. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race..
TABLE SAW : A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK : Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
BAND SAW : A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST : A tool for testing the maximum tensile strength of everything you forgot to disconnect.
PHILLIPS SCREWDRIVER : Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER : A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
PRY BAR : A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50p part.
HOSE CUTTER : A tool used to make hoses too short.
HAMMER : Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
UTILITY KNIFE : Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes.
Haha! Love the hacksaw paragraph. ROFL
Lmao
I've seen most of that before, but enjoyed reading it.
Thanks for the chuckles and smiles Beer
Oh, it's so good to see that I'm not alone in my futility.
(11-18-2021, 06:10 AM)pdedse_imp Wrote: Oh, it's so good to see that I'm not alone in my futility.
Big Grin Big Grin Big Grin
Excellent, and all true!
I love this kind of humor. Thanks for sharing.
Barry , I LOVE your English sense of humor AND the truth in many of your explanations !
(11-18-2021, 07:46 AM)Houtman_imp Wrote: Barry , I LOVE your English sense of humor AND the truth in many of your explanations !
I can't lay claim to this, I'm afraid. John... But they are SO true, aren't they? Big Grin
  OBD Tools Davidjill_imp 9 838 11-16-2024, 02:00 AM
Last Post: Whoops
  Tools you'll need the Ferret 109 9,268 03-23-2023, 11:04 PM
  jerky throttle response... explained (video) jtopiso_imp 0 211 06-09-2021, 04:28 PM
Last Post: jtopiso_imp
  Tools dave 22 1,582 03-17-2021, 01:56 AM
  Mandatory Tools for Road Trip (2017 model and later) 17-CB-002 35 2,772 10-29-2020, 12:03 PM
  IACV explained max 24 1,680 02-26-2018, 09:38 AM
Last Post: SportsterDoc
