Tools you'll need
Front Fork preload.....large flat blade screwdriver
Rear Shock preload.....shock spanner wrench
Front wheel :
axle pinch bolts...... 6 mm allen
r/s axle nut ..... 22 mm
l/s axle head..... 17 mm allen
Wooden mallet
Small phillips screwdriver or rod to fit hole
Rear wheel :
r/s axle nut..... 32 mm. ( 1 1/4" will fit)
l/s axle nut .... 27 mm
Chain adjuster bolts......8 mm
front brake calipers..... 12 mm
Clutch and brake lever clamps..... 8 mm
Handlebar clamps bolts....6 mm allen
Headlight bucket..... 6 mm allen
front fork triple tree clamps upper ..... 12 mm
Lower ..... 14 mm
Side covers .... 5 mm allen (in tool kit)
Battery ..... medium phillips or 10 mm socket
Oil drain bolt ... 17 mm socket
Motor mount bolts ...the ones I could get to were.... 17 mm and.... 14 mm
If I think of anything else, I'll add it later
Whenever possible use 6 point instead of 12 point tools.
Pick up a tube of permatech "Anti- seize" to use on most of your pinch type bolts
And a tube of multi purpose lithium grease or a tub of wheel bearing grease for greasing axles
And a tub of citrus cleaner for your hands. If you are going to work on the bike yourself, you're going to get a little greasy
At Harbor Freight you can pick up a bundle of 50 shop rags for like $7. If one gets really greasy, don't bother washing it, just throw it away.
A roll of paper towels comes in real handy.
I also keep a box of latex gloves on the tool box which helps some, but you are still going to get greasy lol
Nice..so to summarize:
Awesome thanks!!! I was actually thinking about going to get some tools this weekend so I won't have to borrow again in the future ha!
For anyone needing to buy tools I would suggest getting a set of metric box wrenches 8 mm to 19 mm, a set of metric 6 point sockets same sizes, 5 and 6 mm allen sockets, a swivel ratchet, a 3" and a 6" socket extensions, a medium phillips screwdrive, medium and large flat blade screwdrivers and then individually buy your specialty sockets and/ or box end wrenches
22mm, 27mm, 32 mm ( or 1 1/4") and the 17 mm allen socket and a torque wrench ( if you are not confident on tightening fasteners)
I buy most of my stuff at Sears, or Harbor Freight but some specialty stuff I order from mcmaster-Carr.
http://www.mcmaster.com/
I have one suggestion to add to ferret's list. If you are buying tools, consider JIS screw drivers instead of Phillips for working on the CB11 or any Japanese products. They work better and will not slip. These screw drivers are hard to find at the usual tool stores but are available on-line. You can do a search for JIS screw drivers for sources. I ordered mine here. http://www.rjrcooltools.com/shop_item_de...cat_ID=138
I ordered #8971 which gives you two different lengths of the #2 driver. I find that I rarely need a size other than #2.
Well learn something new everyday....jis stands for Japanese Industrial Standard and apparently Japanes screws are not really phillips head but JIS head. Interesting. Apparently if you grind .020 to .030 off the end of a phillips it will do a better job on Japanese screw by going deeper into the slot.
Thanks for the education ridesalot!
I had heard that someplace, but didn't know if was really true. I looked at the rjr site and am going to order a set of these today!
Not a lot of screws on our bikes. I don't even use a phillips on a battery (I use a socket instead) but I would recommend having a phillips or JIS handy for removing caps on mater cylinders etc.
Geez a 32mm combo wrench is hefty!
A great thread and thanks to the ferret for giving us this.
One thing I am a stickler on is the proverbial torque wrench. You really need to include two of them in your list. You will need one that goes from from 0 to 250 inch pounds and another to take you up to at least 80 foot pounds. That's a nice looking 32mm above, but what's missing?
You just cannot do the job properly without knowing you are torqued correctly.
  OBD Tools Davidjill_imp 9 816 11-16-2024, 02:00 AM
Last Post: Whoops
  Tools Explained... Bazbro_imp 12 879 11-19-2021, 03:26 AM
  Tools dave 22 1,511 03-17-2021, 01:56 AM
  Mandatory Tools for Road Trip (2017 model and later) 17-CB-002 35 2,655 10-29-2020, 12:03 PM
