Mandatory Tools for Road Trip (2017 model and later)
Sorry below information applies to 2017 and later models.
I created this post to help other riders prepare a minimum list of mandatory tools required for unexpected repairs during road trip.
All mentions items must be able to fit under the seat except for the air pump.
Electrical issue(s) such as a "No Start" or "No Cranking".
-I have attached a simple hand-drawn copy of the "Starting" and "Ignition" circuits which I copied from the official HONDA Repair Manual.
-Plus a 11x17 copy of the full wiring diagram - which I cannot include due to copyright protection.
-Note: the items above are sealed in a plastic bag (waterproof) and stored under the seat.
-A few feet of electrical tape.
Tubeless Tire puncture Repair Kit
-A plug repair kit (includes the following: a "Reamer", Plug "Insert" tool, a tube of Rubber glue, a knife and a few extra plugs. (see attachment).
-A 90 degree air valve adaptor.
-A compact tire pressure gauge.
-A compact pump is recommended and a separate Tire pressure gauge.
Wrench
-See list of wrenches for different repair.
-Note: For the 22 & 17mm wrenches (Front & Rear tire removal), I cut & got rid of the open end section of the wrench & bent it to use as a tire breaker from the rim. (see attachment).
-The 2 bigger wrenches fits in the the designated U-lock space. (Sorry Peking Duck, I know that you own a U-lock).
Swiss Army Knife
-It includes a plier, knife and other assortment of tools.
Flashlight
-A modified flashlight with 2 external wires that can be hooked up to the 12v battery.
-This can also be used as a flashlight.
-It can also be used to troubleshoot for electrical short circuit.
Spark Plug socket & 1 spark plug.
Due to the exorbitant spark plug price, I carry a previously used (still in good condition) spark plug.
Air plugs
A few extra ear plugs.
more pictures
It's always good to be prepared. A flat rear tire is the most likely failure, and you've got that well covered. The front and rear axles takes a 22mm, with a 27mm on the rear axle nut. I have a spare 27mm from a Triumph Bonneville that, with the extension tube, gives 11" of leverage. Don't forget a 12mm box end wrench or socket for removing the calipers.
Although it's not light, and I can't stuff it under the seat, I've started carrying a small Li-ion battery jumpers in my Aerostich. Also a Battery Tender voltmeter that plugs into the charging socket. Not as good as a multimeter, but frankly, I think it's as reliable electrically and mechanically as my car.
Sure those all can fit under the seat? Mines underseat compartment felt kind of small.
(07-20-2020, 04:56 PM)zirconxi_imp Wrote: Sure those all can fit under the seat? Mines underseat compartment felt kind of small.
Americans have bigger butts, therefore bigger seats and therefore bigger under seat compartments.... , although Canadian models might be the standard size....
The best I like are: electrical diag, tire repair kit, s/plug & Swiss knife Thumbs Up
Great list! Thanks for sharing.
But I’m confused — I thought the 2017 EX models had tube tires, not tubeless.
Good point LE! Actually, I read a while back where Alain had converted his to tubeless: http://cb1100forum.com/forum/showthread.php?tid=14000
Back in the old days before tubeless wire-spoked wheels, we used to replace the rim strip with a couple windings of duct tape. We put an o-ring on the metal valve stem on the inside of the rim. Then another o-ring on the outside with a cupped washer (from an old tube) on top, and finally the stem nut.
It turned a blowout into a slow(er) leak. If the tube tears, it starts wadding up and the imbalance becomes really violent, (like when you're washing 3 pairs of jeans and they all migrate to the same side on spin).
So it made me wonder about plugging a tire with a tube in it. I think, if the puncture doesn't tear the tube, and with the tire plugged and filled, there might be a good chance you can limp somewhere safe.
My tool kit has similar items, but I'm able to put in a CO2 inflator with 4 cartridges, and still have my Kryptonite in there. (I know, 4 cartridges may only get me about 20-25 psi, but I can limp somewhere on that).
I’d like to see Django post up pics of his kit he had with him on the USA tour. Pretty impressive.
Yes, everything fits under the seat except as mentioned the air compressor.
(07-20-2020, 10:44 PM)LongRanger_imp Wrote: Great list! Thanks for sharing.
Yes, Pekingduck is correct, I converted to tubeless and it worked very well.
  OBD Tools Davidjill_imp 9 836 11-16-2024, 02:00 AM
Last Post: Whoops
  Cam chain model and relpacement. syncronizator_imp 19 1,749 10-20-2023, 08:45 PM
  Tools you'll need the Ferret 109 9,181 03-23-2023, 11:04 PM
  What is the Correct Chain Size for a 2014 Model? chync_imp 12 1,164 02-28-2023, 01:16 AM
Last Post: Maturecheese_imp
  Tools Explained... Bazbro_imp 12 904 11-19-2021, 03:26 AM
  2010 model Power Commander alternative? 83NZA_imp 7 634 08-03-2021, 02:04 PM
Last Post: Aussieflyer
  Parts interchangability on US model years '13/'14 vs. '17? Whoops 7 693 04-13-2021, 12:05 PM
  Tools dave 22 1,580 03-17-2021, 01:56 AM
  Rust/corrosion - 2015 EX model N4RN_imp 7 685 10-26-2020, 08:25 PM
Last Post: syncronizator_imp
  Fuel tank interchangeability? Model difference questions.... 2014ltdltz 5 715 10-12-2020, 11:59 PM
Last Post: 2014ltdltz
