Clutch Fluid
(05-08-2023, 07:48 AM)Nachodaddy_imp Wrote: That reminds me, I need to change my coolant.
dont forget the tstat and a new gasket as well, Tongue
(05-08-2023, 07:33 AM)Cormanus_imp Wrote: He is indeed: Tev62.
O0o0o thats Tev! Nice guy I didnt know he had a channel. I'll have to follow
Also I did my Front brakes and Clutch flush earlier.
My clutch reservoir was real dirty and the bottom if the reservoir looked like it had algae growing in it lol. I had to give it a scrub with a clean nylon brush and fill/remove a few times to get the crap out.
Flush was easy after that. Took me a few min to realize the Shift linkage and rod had 2 dots that correspond to each other. I marked a line with a soap stone before I took it off and then accidently washing it off when I was wiping off all the dirt and oil while the cover was off.
Felt good to be able to get something done. [Image: 162c6d98041595753a6467267cc402ef.jpg][Image: 784c6be8bf288c758a3723dee3952268.jpg][Image: ea92c5c69da53e780475777f1e2f8b99.jpg][Image: bb35d65cc7e22f755d90248bd8775fc7.jpg]
MVK24, glad it worked out for you. Your photos make it all much clearer, too. Thanks.
dont forget the tstat and a new gasket as well, Tongue Thumbs UpROFL
Hmmm. That was quite the sewer mvk24.
Hmmm. That was quite the sewer mvk24. Yea I'm not sure how lol. I'm very meticulous with my vehicles. I didnt have a leak that I know of but might be worth ordering a new gasket for the master cylinder. It really did look like there was a thin layer of moss or something on the bottom.
Lots of dirt and corrosion in this reservoir!
Pictures and videos much appreciated....
(05-08-2023, 07:35 PM)Wagonpeddler_imp Wrote: Pictures and videos much appreciated....
No problem,
For anyone else looking for a photo of where the clutch fluid bleeder is i'll circle it.
Once you take off your Gear shift linkage (1 10mm bolt), you then remove the cover behind it thats being held on with 3 Allen key bolts. [Image: 7d1b3a61ea3cc5ac84687e72300f63ec.jpg]
As long as it is the very best bottled stuff from the top of Humphreys Peak Smile.
As long as it is the very best bottled stuff from the top of Humphreys Peak Smile. Only the best.
Thumbs Up
Biker
  CLUTCH FLUID CHANGE SUPERCRUZ_imp 15 1,366 12-24-2025, 11:14 AM
  Replace clutch Lever Davidjill_imp 10 1,040 02-06-2025, 01:27 AM
  Clutch Plates finally going? misterprofessionality 12 1,144 11-22-2024, 07:49 AM
  Brake fluid flush CB1100@2013: photos valkyrie_rider_imp 0 263 02-13-2024, 10:28 AM
Last Post: valkyrie_rider_imp
  Clutch fluid change CB1100@2013: photos valkyrie_rider_imp 0 260 02-13-2024, 10:27 AM
  Clutch Not Working Henrik_imp 7 701 04-24-2023, 06:43 PM
Last Post: Henrik_imp
  Clutch pull mpuhl_imp 4 540 02-21-2023, 10:48 AM
  Synthetic Brake Fluid Wagonpeddler_imp 3 408 02-18-2023, 07:49 AM
  Clutch slave cylinder gasket Maturecheese_imp 3 413 01-27-2023, 12:33 AM
Last Post: Maturecheese_imp
  brake & clutch adjusters The Gecko_imp 10 929 11-25-2022, 08:47 AM
