2017 Honda CB1100EX modifications
That's super helpful! Will take a read through before deciding what to do.
I guess it's good to know it's a common issue.
US regulations call for a near-vertical license plate mounting, with a white light shining on it, often resulting in taillight "extension" pieces added on, or in this case, an extended housing, which becomes a pendulum on a longer stick. UK and other countries allow a more slanted plate, and thus the taillight is tucked in more forward.
My guess is that after the bike's design was finalized, during the process of modifying things for different markets, the light was changed, but perhaps not extensively re-tested, as it seems a minor change.
I put a UK taillight on mine just for its appearance, but can't say how it would hold up in the long term.
https://cb1100forum.com/forum/showthread...=taillight
Oh man, that looks a thousand times better! Thanks for sharing PekingDuck!
Will see if I can dig one up for a swap. Did it happen to require different size bolts?
It just bolted in as I recall. I just looked it up, and the price is a shocker. The whole LED taillight is a lot worse!
(02-05-2024, 11:55 AM)pekingduck_imp Wrote: It just bolted in as I recall. I just looked it up, and the price is a shocker. The whole LED taillight is a lot worse!
The two rubber washers cost 68 cents. I haven't had any more wobble/looseness.
You gents are great. Much appreciate all the info. I'm working on a new plate bracket and will give the washer method a try along with it. I should have some washers laying around that would fit. At least as a test anyway. If not, local hardware shop will have 'em. Fingers-crossed they don't strip as others encountered.
That all said, sourcing the slim cover would be great. Seems like a pricey proposition for something so minimal, but I do think it really cleans up the rear in a way that ties together the overall design. OEM+ Cool
Also, it looks like the bolts are different for the shorter cover. Which makes sense, since the longer bolts may already be too long as is (causing the wobbling).
You can see the shorter bolts here:
[Image: 2cc4f524b81e0e74c73e33cd91c8de67.png]
(02-06-2024, 03:13 AM)FlipModeOne_imp Wrote: You gents are great. Much appreciate all the info. I'm working on a new plate bracket and will give the washer method a try along with it. I should have some washers laying around that would fit. At least as a test anyway. If not, local hardware shop will have 'em. Fingers-crossed they don't strip as others encountered.
I too had the wobbling tail light. Found a couple of o-rings in the toolbox and rolled them up the bolt. That's all it took to snug them up and take the wobble/rattle away.
I thought I posted the final pics. I added the bottom hole but it is covered by the plate frame for the most part. [Image: 982bb4dbc4b60b20c6f92b2d2dac90e7.jpg][Image: afe47220e9389e50cb17edce050f8f8b.jpg][Image: fe6cd415e0969607683449a7f00f38d0.jpg]
Sent from my SM-S908U using Tapatalk
Sorry for never updating here. I was able to tighten up the tailblight with some simple stainless washers on the bolts. Worked like a charm.
Bought some aluminum stock to make a plate bracket, but life seems extra busy lately so the project waits.
  Basic Questions About Dynoject V on 2017 CB1100EX dougwene_imp 9 936 12-29-2024, 03:22 AM
Last Post: Karidis
  2017 CB1100EX Accessory Plugs TXBikerGuy 13 1,202 06-24-2023, 08:27 AM
  Cast wheels 18 inch on 2017 CB1100EX with Spoke wheels supruet_imp 5 660 05-13-2023, 05:43 AM
  2018 CB1100EX just collected from service Motorsport3_imp 5 560 05-10-2023, 11:25 PM
Last Post: Motorsport3_imp
  2017 CB1100EX Brake Bleeding M1tch_imp 1 303 03-05-2022, 04:29 PM
  2017 CB1100ex / Flat tire issue and save Senna02_imp 27 2,132 07-19-2021, 08:28 AM
  Shinko 777 tires for my 2017 CB1100ex Chuckk_imp 314 25,933 12-14-2020, 02:42 AM
Last Post: jimgl3_imp
  2017 CB1100EX Dart Marlin Flyscreen TXBikerGuy 4 446 07-23-2020, 11:22 AM
  New Key for 2017 CB1100EX michael1954 9 791 04-01-2020, 02:26 AM
Last Post: michael1954
  How to adjust the front forks on a 2013 CB1100 and a 2017 CB1100EX. michael1954 13 1,008 02-28-2020, 07:56 AM
