Valve Adjustment Intervals
I had my 2013 checked at 48K and it was in spec.
With 10k on my 2017 looks like I will be doing the valve ck at 12k. I'm assuming it will probably close to spec with no adjustment necessary as with most of my later model Hondas. Has anybody found their valves needing adjustment at 12k?
That’s good to hear, hopefully mine will be within specs
Mines not an EX but my 2014 had 20000 miles when I checked and was all perfectly in spec.
I still haven't checked mine.... [Image: 1b719f286a3aadb01b286da3cb60a0e4.png][Image: a666c8f057e828d19b949d70c09406e6.jpg]
Sent from my Pixel 6 using Tapatalk
I haven't checked mine either but I only have about 1/2 the miles of MMC lol
Man at the miles you guys have I won't have to check mine until after I'm dead! Wink
Have never pulled of my valve cover yet... at 83,000 miles..
(04-10-2025, 07:37 AM)balkanhound_imp Wrote: With 10k on my 2017 looks like I will be doing the valve ck at 12k. I'm assuming it will probably close to spec with no adjustment necessary as with most of my later model Hondas. Has anybody found their valves needing adjustment at 12k?
I check/adjust my valves every 24k after initial 12k check when the dealer told me all was in spec. At 24k miles I typically have several valves on the boundary or 0.01mm out of spec. So my checks were at 12k, 36k, 60k and next check is soon to be at 84k miles.
I think the valve checks are pushing your valves out of spec. Smile
  Valve Adjustment Shims dave 13 702 07-28-2026, 12:49 PM
Last Post: MagnaRider
  Valve Adjustment and Camshaft Removal dave 5 627 03-21-2026, 04:49 PM
  Valve Adjustment dave 6 861 08-29-2025, 10:46 AM
  Valve Cover Baffle lining ? bflint 6 939 07-26-2025, 11:27 AM
Last Post: bflint
  Rear Brake Pedal Adjustment Gone in 60 12 1,137 04-04-2024, 08:18 AM
  Valve Adjustment Tolerances - How Far Do You Go? dave 14 1,495 10-18-2023, 09:28 PM
Last Post: The Gecko_imp
  Observed Valve Clearance Cormanus 16 1,447 03-06-2023, 09:03 AM
Last Post: Tejas_imp
  The OBSERVED Valve Clearance thread Pterodactyl_imp 162 12,588 12-27-2022, 08:35 AM
  Checking valve clearances Maturecheese_imp 74 6,508 12-11-2022, 12:56 PM
  Valve noise (i think) Maturecheese_imp 6 640 07-08-2022, 03:41 AM
Last Post: 1973cb750
