Puig Dark Smoke Naked on '14 std
Rocky_imp Offline
Threads: 26
RE: Puig Dark Smoke Naked on '14 std
On the basis of what was said here, and on looks only, I ordered one from Amazon and it's in the mail.
I'll let you know how I like it or not.
I figured for the reasonable cost I would try it. If it fails to please I can get a National Cycle shield from a Canadian supplier and experiment with that.
05-22-2014, 12:37 AM
MFGUSA_imp Offline
Threads: 6
Absolutely Rock- that was my thought too.
The Harley guys were all around my CB at work today- one in particular with a Night Rod liked the Puig on there. They all loved the bike. I can't believe the looks this Honda is getting.
..incidentally I tried to tuck the brackets behind the bucket supports again with no success. Way too tight. Like trying to wear swim trunks meant for a 8 year old. I will make new brackets. It appears the '14 gauges are bigger than the previous years. Can anybody verify this?
05-22-2014, 05:57 AM
thessler3_imp Offline
Threads: 7
MFG USA - did you try disconnecting the mounting brackets from the shield and flipping them over so the bend in the brackets is towards the headlight?
I mounted mine this way and they fit inside the headlight brackets just fine.
Mine is a 2013 and I have read the 2014 headlight is a bit higher, so I cannot be sure it will work for you.
05-28-2014, 02:24 AM
MFGUSA_imp Offline
Threads: 6
Yeah, I tried every possible way with the brackets. I like how quick I can remove it in its current configuration. It only took a moment and I was off and riding.
I did mount the brackets inside- and it looks nice, but I used stainless spacers to ease the pressure on the gauge cluster. I try that for awhile.
05-28-2014, 05:45 AM
Offroad Offline
Indiana
Threads: 51
Likes Received: 7 in 3 posts
Thanks for the post! I just order one from Amazon too!
http://www.amazon.com/Puig-1482F-Smoke-W...B00GA3CMZM
Wasn't listed for my 2014 Std, ordered for 2013, hope it fits!
05-28-2014, 12:32 PM
Likes Received: 174 in 72 posts
#26
If you mount it on the inside of the headlight bracket, you do run the risk of the upper front bolt scraping the outside of headlight housing.
05-28-2014, 02:20 PM
MFGUSA_imp Offline
Threads: 6
#27
(05-28-2014, 02:20 PM)EmptySea_imp Wrote: If you mount it on the inside of the headlight bracket, you do run the risk of the upper front bolt scraping the outside of headlight housing.
I looked in there- there is plenty of room between the screw and bezel.
offroadfx4 it is not a perfect fit as I am sure the gauges on the '14 occupy more space than on the '13.
I did take a string and wrap it around the assembly and measured it. 27 3/8". If anyone here could do the same with their '13, then we would know for certain.
05-28-2014, 08:10 PM
#28
It may be different on the DLX (I think the headlight mount is different), but I'm here to tell you that it can, and did, scratch the bezel on at least one 2013 bike.
05-28-2014, 08:42 PM
MFGUSA_imp Offline
Threads: 6
#29
Well then, scratch one bezel. Is the bezel chrome or polished stainless? I would imagine chrome.
05-29-2014, 10:03 AM
#30
The scratch is mine. Just want ppl to know that they may want to consider filing the end of the screw or covering it, if it looks like it will contact the housing.
05-29-2014, 11:23 AM
   to puig or not to puig (or, which Puig screens fit ?) j3gq_imp 53 3,792 05-30-2022, 04:13 AM
Last Post: j3gq_imp
  Puig Vision Windscreen Interceptor Pilot_imp 5 606 03-03-2022, 08:39 AM
  Puig now listing the CB1100 CB4ME_imp 8 699 01-24-2022, 04:34 AM
Last Post: j3gq_imp
  Puig Plus install question Rolls_imp 16 1,343 01-24-2022, 04:33 AM
Last Post: j3gq_imp
  Puig Windscreen Quality Skypilot_imp 13 998 11-01-2019, 11:43 AM
Last Post: MWV1500_imp
  Road Comet II: Puig Clip-on Visor? Townie_imp 5 500 08-10-2019, 05:16 AM
Last Post: warman_imp
  Puig Stainless Steel Engine Bars Macduff_imp 2 354 07-28-2017, 12:45 AM
Last Post: Archie_imp
  Naked or skimpily clad ? the Ferret 57 3,282 04-30-2017, 05:12 AM
Last Post: Nortoon_imp
  Puig Windscreen Hondadawg1_imp 8 652 02-05-2017, 11:13 AM
Last Post: Hondadawg1_imp
  (HELP) Puig 0869N Black Naked Universal Windshield question.. pwh421_imp 9 1,284 08-08-2016, 04:59 AM
Last Post: Ctatyk_imp
