Puig Stainless Steel Engine Bars
Macduff_imp Offline
Threads: 11
I'd intended to fit some engine bars to my '17 CB11RS for some a while but wanted stainless steel ones and wasnt able to locate any until i found a set listed as being for a '13 CB1100 on ebay. They were a bit spendy at over 210 quid (UK sterling) but managed to find a set at nearly 100 quid less on ebay so decided to take a chance that the frame hadn't change any in the lower frame rail area between the different model years. The use the lower engine mount bolt as the front mount and have a u-bolt clamp with a plastic shim to deter paint damage for the rear mount around the lower frame rail.
On the RHS bar I had to reverse the engine bolt so that the nut was on the outside as the bar shape prevented the long bolt from going through the mount hole, the LHS had more clearance so the bolt could go back the way it came out with the bolt head outward. Some pics of the bars and installed below.
Fitting of the u-bolt and its clamp was slightly fiddly especially trying to keep the plastic shim in place and on the LHS the u-bolt clamp had to straddle a lower frame rail weld which made it a little bit more awkward. But overall these fitted well without needing gentle persuasion with a hammer or lever to get the holes/bolts lined up which is a vast improvement on some (inc OEM) engine bars I've fitted to other bikes over the years.
07-28-2017, 12:26 AM
Threads: 698
Likes Given: 792
RE: Puig Stainless Steel Engine Bars
Looking good!
07-28-2017, 12:40 AM
Archie_imp Offline
Threads: 4
Beauty!!
07-28-2017, 12:45 AM
  SW-MOTECH Crash Bars / Engine Protectors rdprdp01 1 378 04-12-2025, 08:57 AM
Last Post: 17-CB-002
  Fehling crash bars Newceebee_imp 13 1,063 02-03-2025, 11:47 PM
  SW-MOTECH Crash Bars / Engine Protectors rdprdp01 11 1,100 11-03-2024, 05:24 AM
Last Post: WRXer_imp
  Crash bars question from Biker Dave the Ferret 36 2,631 06-14-2023, 02:35 PM
   to puig or not to puig (or, which Puig screens fit ?) j3gq_imp 53 3,672 05-30-2022, 04:13 AM
Last Post: j3gq_imp
  Puig Vision Windscreen Interceptor Pilot_imp 5 600 03-03-2022, 08:39 AM
  Puig now listing the CB1100 CB4ME_imp 8 680 01-24-2022, 04:34 AM
Last Post: j3gq_imp
  Puig Plus install question Rolls_imp 16 1,326 01-24-2022, 04:33 AM
Last Post: j3gq_imp
  Grab bars for pillion Endeavour_imp 1 362 05-15-2021, 08:34 AM
  Crash bars do not fit. olafurarason_imp 3 448 04-22-2021, 12:11 AM
Last Post: olafurarason_imp
