(HELP) Puig 0869N Black Naked Universal Windshield question..
pwh421_imp Offline
Threads: 11
I ordered this, and it arrived today.. It looks like it is going to be almost vertical instead of swept back.. Is that normal fitment, or is this the wrong screen?
also there is a third, slightly longer mounting screw shown in the installation guide that there is no receiving hole for on my CB..
07-31-2016, 10:30 AM
White Dog_imp Offline
Threads: 59
RE: (HELP) Puig 0869N Black Naked Universal Windshield question..
You probably received a generic or universal fit kit of various bolts, washers, nuts, etc. As I remember, the 2 small holes on the bracket are to mount the shield to the bracket with real short bolts. The large hole (below the 2 small ones) mounts to your headlight bolts.
08-03-2016, 01:32 AM
Hondahawkrider_imp Offline
Threads: 14
i think that's the same screen i have. There should be mounting brackets to angle it, but it creates a gap over the headlight.. I got mine cheap off amazon as a left over, so I wasn't too upset (just needed one fast for the rally). I found that, while a bit more vertical it does a good job.
08-03-2016, 03:23 AM
Ctatyk_imp Offline
Threads: 0
I got mine from Amazon yesterday and did some fitting. The only thing that I found a little disconcerting was that it was right up against my instruments. So, I'll be doing a little bit of padding on the backside of the shield to protect them from any issues.
It does seem to sit fairly vertically, but I think that I like that look on the bike. It's like a mini-wind screen and I don't care for full sized screens on naked bikes.
I'll be creating a quick release set-up for mine this fall because there are times when I just don't want a screen and taking everything loose is a waste of time.
08-04-2016, 02:09 AM
dsinned_imp Offline
Threads: 22
I just got mine this week also from Amazon with free shipping. It looks fairly decent on an all black 2014 (standard) CB1100. However, I'm sure the actual wind protection will be minimal, but I got it mainly to improve the aerodynamics slightly and looks of the bike at an AMAZING price.
I haven't installed it yet, but looks like it will be a nice tight fit with minimal installation difficulty. The only confusing factor is whether to insert the headlight bolts' bracket on the inside or outside of the headlight mounting bracket ears. I think it should go on the inside so the shield's brackets are not (as) visible on the sides of the headlight.
08-04-2016, 02:26 AM
Threads: 14
(08-04-2016, 02:09 AM)Ctatyk_imp Wrote: I got mine from Amazon yesterday and did some fitting. The only thing that I found a little disconcerting was that it was right up against my instruments. So, I'll be doing a little bit of padding on the backside of the shield to protect them from any issues.
hmmm.. mine came with 2 small foam pads that had sticky stuff on one side... it was peal and put em between the instruments and shield
08-04-2016, 03:21 AM
BayAreaRick_imp Offline
Threads: 4
Can we see a few pictures - front-view, side-view and close-up? Would be appreciated.
08-04-2016, 03:26 AM
pwh421_imp Offline
Threads: 11
In the end I got it mounted and it it's fine, in fact it is sort of awesome. It makes a huge difference on the road.. I'll post pics of it mounted as soon as I can..
Thank you all for the support and thoughts.
-Peter
08-07-2016, 11:41 PM
dsinned_imp Offline
Threads: 22
Same here, although I put Puig's left and right side mounting brackets under the bolts on the "outside" of the headlight bucket ears. I don't think its possible to go the other way. Those brackets are chrome plated, so they look alright in this position and easier to make adjustments to the "tilt angle" of the screen.
08-08-2016, 03:06 AM
Ctatyk_imp Offline
Threads: 0
Yeah, mine had those too, but I thought that the felt a little thick. Was going to see about a slightly different arrangement, but I found that those pads slid into place pretty well when mounted.
Thanks for looking out for me. Thumbs Up
08-08-2016, 04:59 AM
  Givi Airstar Universal Windshield - A660 peterbaron 2 610 12-28-2025, 02:15 PM
  I installed the Emgo Reverse Cone Universal slip on danieljrmurray_imp 2 390 05-15-2023, 04:29 AM
Last Post: 3rd Gear Steve
  Wanted. Chick design comet 2 windshield Nightryder22_imp 15 1,239 01-22-2023, 03:07 AM
  windshield Griz53_imp 3 377 09-24-2022, 04:55 AM
Last Post: 1985CB450_imp
   to puig or not to puig (or, which Puig screens fit ?) j3gq_imp 53 3,553 05-30-2022, 04:13 AM
Last Post: j3gq_imp
  Puig Vision Windscreen Interceptor Pilot_imp 5 579 03-03-2022, 08:39 AM
  Puig now listing the CB1100 CB4ME_imp 8 660 01-24-2022, 04:34 AM
Last Post: j3gq_imp
  Puig Plus install question Rolls_imp 16 1,292 01-24-2022, 04:33 AM
Last Post: j3gq_imp
  Givi AF49 Airflow Universal Windscreen binarkansas_imp 3 408 09-23-2021, 07:02 AM
Last Post: LikeAfox_imp
  Windshield With Vertical Lip eddi0_imp 8 844 06-12-2021, 08:50 PM
Last Post: Randy B
