Aluminum sprocket cover ('13) fit? (Samurider)
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 136
RE: Aluminum sprocket cover ('13) fit? (Samurider)
I'd like to see that too Chip. Thanks!
03-30-2015, 12:03 AM
Papa Weeley_imp Offline
Threads: 44
Just FYI, I ended up buying this piece right after I posted this, and mine came with the three screws necessary for mounting from Mr. T. As stated earlier, it mounts up very sturdily with just the two screws and the third mounted un-attached with a nut on the back to hold it on. Looks great, too:
[url=http://s157.photobucket.com/user/mustangfeverrr/media/2015-2-16-1%20073_zpsnpwl0ria.jpg.html][Image: 594691ee68a90d68237d63f326af79f7.jpg]
03-30-2015, 04:20 AM
the_undecider_imp Offline
Threads: 43
Here is my thread on adding a small bracket for the 3rd mounting point:
http://cb1100forum.com/forum/showthread.php?tid=4782
If you don't transfer the rubber grommets to the new cover, I would recommend a stainless washer to help fill the mounting holes. The head of the bolts isn't much bigger than the holes in the cover. If you use the grommets, two mounting points isn't enough since the rubber let's the cover wiggle around.
03-30-2015, 04:33 AM
Lord Popgun Offline
Virginia
Likes Given: 136
I had forgotten all about that thread. Thanks undecider.
03-30-2015, 08:04 AM
huxley2_imp Offline
Threads: 1
Looks way better. I'm going to pull the trigger soon.
04-08-2015, 11:38 AM
CB4ME_imp Offline
Threads: 183
In my opinion it's one of the best mods you can do to a 2013.
Papa - your bike is looking mighty fine!
04-09-2015, 06:21 AM
Threads: 44
Thank you, sir! Smile
04-13-2015, 08:56 AM
  Samurider experience? Cormanus 27 2,087 02-13-2026, 08:17 AM
Last Post: suhawk305
  2017 EX Accessories at Samurider CB4ME_imp 7 665 01-29-2026, 05:41 PM
Last Post: JRD
  power port and Samurider Road Comet Fairing 1 tdbru 9 973 05-04-2025, 07:20 PM
Last Post: tdbru
  MIZ front fender and tail cowl on Samurider CB4ME_imp 16 1,428 06-27-2022, 12:52 PM
Last Post: CB1100CB_imp
  Samurider Paniers-review + pictures tomas_imp 76 5,900 05-03-2022, 02:35 PM
Last Post: ChiefJP_imp
  best sprocket swap for city commuter acceleration... boynton6spd_imp 3 334 12-04-2020, 12:35 PM
Last Post: 17-CB-002
  More handlebar talk - Samurider Type 2 replacements GrabOn_imp 10 900 07-23-2020, 01:16 AM
Last Post: KiowaEagle_imp
  Rear Sprocket Nuts 89gaz89_imp 3 344 05-02-2020, 07:35 AM
  19 tooth countershaft sprocket physics-teacher_imp 19 1,387 12-13-2019, 09:41 PM
Last Post: marel_imp
  Smaller rear sprocket? DBM_imp 11 831 08-14-2019, 10:50 AM
Last Post: jimgl3_imp
