Rear Sprocket Nuts
89gaz89_imp Offline
New to the Forum
Threads: 2
Rear Sprocket Nuts
Hi,
I have just taken my wheels in for powder coating and I want to change my Rear Sprocket Nuts for Stainless ones - anyone know the size please.
Gaz
CB1100RS 2017
Thanks
05-01-2020, 10:23 PM
Ben70_imp Offline
Threads: 23
RE: Rear Sprocket Nuts
They are special. Listed as 12 mm fuse rashi. Kind of like nyloc only different.
Ben
05-02-2020, 12:20 AM
89gaz89_imp Offline
New to the Forum
Threads: 2
Cheers Ben
Gaz Thumbs Up
05-02-2020, 05:49 AM
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
As Ben says above, they are 12mm. And they have a stainless locking spring built in that means they can be re-used, unlike Nyloc, which deform and then don't grip anymore.
Since you are replacing them, you could powdercoat them also, as long as the threads and mating face are covered, as by threading them onto a bolt. The powdercoat should hold up as long as you use a 6-point socket, and tighten by hand. When I want to protect a bolt head's appearance, I have a piece of paper or rag between the socket and the head.
05-02-2020, 07:35 AM
  best sprocket swap for city commuter acceleration... boynton6spd_imp 3 354 12-04-2020, 12:35 PM
Last Post: 17-CB-002
  19 tooth countershaft sprocket physics-teacher_imp 19 1,429 12-13-2019, 09:41 PM
Last Post: marel_imp
  Smaller rear sprocket? DBM_imp 11 925 08-14-2019, 10:50 AM
Last Post: jimgl3_imp
  WANTED - 19T Front Sprocket CTsCB_imp 0 238 07-24-2017, 03:52 PM
Last Post: CTsCB_imp
  Carbon Fiber Sprocket Cover Anyone? aschem_imp 7 513 09-22-2016, 11:34 PM
Last Post: Elipten_imp
  Samurider front sprocket cover Steverino_imp 6 557 01-12-2016, 02:10 PM
Last Post: Ron in MO_imp
  19T PBI Sprocket redbirds_imp 6 504 01-07-2016, 10:40 AM
Last Post: redbirds_imp
   Samurider Sprocket Guard Hedge_imp 4 443 05-04-2015, 09:43 PM
Last Post: Hedge_imp
  Givi Rear Rack vs. Honda OEM Rear Carrier lagoje_imp 29 1,732 04-24-2015, 06:03 AM
Last Post: specialist8
  Aluminum sprocket cover ('13) fit? (Samurider) Papa Weeley_imp 16 1,109 04-13-2015, 08:56 AM
Last Post: Papa Weeley_imp
