19 tooth countershaft sprocket
physics-teacher_imp Offline
Threads: 9
I'm finding a lot of older references to vendors for 19 tooth sprockets but I'm having trouble finding one that is currently producing. They all want you to go down some teeth for crotch rocket acceleration. Any ideas, please?
08-30-2016, 07:43 AM
Ron in MO_imp Offline
Threads: 14
RE: 19 tooth countershaft sprocket
(08-30-2016, 07:43 AM)physics-teacher_imp Wrote: I'm finding a lot of older references to vendors for 19 tooth sprockets but I'm having trouble finding one that is currently producing. They all want you to go down some teeth for crotch rocket acceleration. Any ideas, please?
Many of us 2013 CB1100 owners have converted their front sprocket to a 19T cog and love the results. Here is a link to the company I purchased mine from:
http://www.shop.pbisprockets.com/product...oductId=66
PBI Sprockets are quality units and are reasonably priced.
08-30-2016, 08:28 AM
Threads: 9
Thanks so much. Funny, I could have sworn I tried this site before and did not find the 19 tooth. Maybe they were temporarily out of production? Anyway, I've ordered.
08-30-2016, 08:58 AM
Threads: 14
(08-30-2016, 08:58 AM)physics-teacher_imp Wrote: Thanks so much. Funny, I could have sworn I tried this site before and did not find the 19 tooth. Maybe they were temporarily out of production? Anyway, I've ordered.
My pleasure! Let us know how you like the change in performance.
08-30-2016, 09:30 AM
use2b_imp Offline
Threads: 39
Thanks Ron , I will have to pull the cover and count mine because Ferret has given me RPM envy............
plan on a trip to Barber in 5 weeks so I gotta decide.
08-30-2016, 10:08 AM
CIP57_imp Offline
Threads: 68
PT,
Your going to have to trim the chain guide (front) so it doesn't rub against the chain. Take out the bolts put it in a vice and trim it down with a grinder or file.
Here is the link::
http://cb1100forum.com/forum/showthread....t=19+tooth
08-30-2016, 08:32 PM
Threads: 14
PT,
Here is the link::
PT / CIP57,
I saw this thread too, but did not have to trim my chain guide and there has been no rubbing. Don't know why mine was different but just an FYI in case.
08-31-2016, 01:09 AM
Threads: 9
Or maybe I'll take the lazy way and let the chain do the grinding! First to go will be the guard, then the crankcase cover, then half of my left leg! Smile
08-31-2016, 05:45 AM
CIP57_imp Offline
Threads: 68
(08-31-2016, 05:45 AM)physics-teacher_imp Wrote: Or maybe I'll take the lazy way and let the chain do the grinding! First to go will be the guard, then the crankcase cover, then half of my left leg! Smile
LMAO
You'll know when you try to get the cover on and it doesn't seat properly.
08-31-2016, 05:53 AM
Threads: 9
First impressions of my 19 tooth sprocket. Messier job installing than I'd hoped; I'll have black grease under my fingernails for a long time. It was dirty in there! Low end acceleration does not seem to be affected at all, though this should be impossible. Main thing I notice: the bike seems more relaxed even in lower gears and vibrate less, if that's possible! In top gear, especially, the bike seems to be loafing effortlessly with NO vibration. Of course, some of this can be the expectancy effect: I see what I expected whether it's real or not. I am guessing the main calming effect may be from the fact that the chain now goes around a larger-radius curve with the 19 compared to the 18. As we all know (?) chains don't like going around sharp radius curves and will wear faster because the load is spread over fewer teeth. At the very least, I should be prolonging chain life, and I think the chain is thanking me for increasing its radius of curvature. In sum, I wholeheartedly recommend this mod.
09-04-2016, 05:36 AM
  best sprocket swap for city commuter acceleration... boynton6spd_imp 3 380 12-04-2020, 12:35 PM
Last Post: 17-CB-002
  Rear Sprocket Nuts 89gaz89_imp 3 371 05-02-2020, 07:35 AM
  Smaller rear sprocket? DBM_imp 11 956 08-14-2019, 10:50 AM
Last Post: jimgl3_imp
  WANTED - 19T Front Sprocket CTsCB_imp 0 244 07-24-2017, 03:52 PM
Last Post: CTsCB_imp
  Carbon Fiber Sprocket Cover Anyone? aschem_imp 7 550 09-22-2016, 11:34 PM
Last Post: Elipten_imp
  Samurider front sprocket cover Steverino_imp 6 562 01-12-2016, 02:10 PM
Last Post: Ron in MO_imp
  19T PBI Sprocket redbirds_imp 6 513 01-07-2016, 10:40 AM
Last Post: redbirds_imp
   Samurider Sprocket Guard Hedge_imp 4 470 05-04-2015, 09:43 PM
Last Post: Hedge_imp
  Aluminum sprocket cover ('13) fit? (Samurider) Papa Weeley_imp 16 1,135 04-13-2015, 08:56 AM
Last Post: Papa Weeley_imp
  2013 6 Speed Upgrade - AKA 2014 DLX Sprocket Cover the_undecider_imp 7 665 01-28-2015, 03:04 AM
