Removing stock mufflers?
Ron in MO_imp Offline
Threads: 14
RE: Removing stock mufflers?
Mike. Like everyone has replied, it's a fairly simple task.
I would loosen the front muffler clamp first, then unbolt the muffler at the rear bracket. Once the rear bolt is pulled out, the muffler may drop down a little bit. At this point you can grab the muffler and rotate it with a slight up and down motion, while pulling towards the rear of the bike. It should slip off pretty easy. Use this same process for both sides.
The Over Racing mufflers have a different muffler gasket, which should have been included with them. Look to make sure your OEM muffler gaskets didn't stay on the muffler end of the header pipes. Remove them if they did. I use the exhaust temperature Permatex paste to seal the new muffler gaskets. Install of the new mufflers is the reverse process, with everything slipping easily into place.
Good luck and let us know how you like the new sound. I'm noticing mine sounding even better the more miles I put on them.
02-11-2016, 09:23 AM
Rebel73_imp Offline
Threads: 79
Excellent. Great tips. Thanks, y'all.
02-11-2016, 09:37 AM
Mike546_imp Offline
Threads: 4
(02-11-2016, 06:29 AM)Mike546_imp Wrote:
(02-11-2016, 04:31 AM)Rebel73_imp Wrote: Cool, guys. Thanks for your input and tips. I'll post some pics and try to put up a video, too!
Are you selling your stock DLX mufflers?
Mike, I'm not sure. For the time being I will probably hang onto them because you never know. Should I decide to sell them I'll let you know.
Ok cool, let me know if you do decide to sell them.
thanks
Mike
02-11-2016, 11:22 AM
Magnus_imp Offline
Threads: 2
There will be a small heat shield attached to the stock muffler pipe. Just remove the one allen bolt and then then slide the cover to the side to release it.
Other than that just the one mounting bolt by the muffler and muffler clamp where it attaches to the catalytic converter. Easy Peasy.
02-15-2016, 05:31 AM
uscgmac_imp Offline
Threads: 23
Make sure to wipe down and clean mufflers with some clean paper towl and windex or similar type cleaner to get off all finger prints and grease or and smudges prior to stating for first time. If you dont do this it will leave a permenant mark on them.
02-15-2016, 06:28 AM
Rebel73_imp Offline
Threads: 79
I installed the Over Racing mufflers this weekend. It was very easy. They sound great! I'll see if I can get a video up soon. There is a gap where you can see a black section where the mufflers meet the headers. I'm going to do as another member did and transfer the covers from the stock mufflers. It actually doesn't look bad as it is. So far I'm very happy with them. There's a nice "bwaap" when I rev it and it sounds really sweet under load. The sound level is perfect. I can hear them but they are not deafening or annoying!
[url=http://smg.photobucket.com/user/RobertB755/media/20160215_162228_zps5qqlavzs.jpg.html][Image: f0b09fec6c0d4cfd224cc913650e4543.jpg]
[url=http://smg.photobucket.com/user/RobertB755/media/20160215_162233_zps9krni6ef.jpg.html][Image: 1932311f38878339ddf73cec46b2a14d.jpg]
02-15-2016, 12:54 PM
uscgmac_imp Offline
Threads: 23
Very nice. They look expensive. Lol.
02-15-2016, 08:04 PM
Chapomis_imp Offline
Threads: 64
Nice job Rob, can't wait to hear them
02-15-2016, 09:26 PM
Threads: 698
Likes Received: 623 in 279 posts
Likes Given: 789
Those look great especially on that café style bike.
02-15-2016, 09:53 PM
MikeOxbig_imp Offline
Threads: 8
Looks great Rob! Thumbs Up Hope it sounds as good as it looks.
02-16-2016, 04:40 AM
  Stock Mirrors MrBob_imp 5 589 04-11-2025, 03:33 AM
Last Post: balkanhound_imp
  Stock Exhaust Mod SStan11_imp 79 5,185 03-12-2025, 04:32 AM
  Stock Muffler jbird06_imp 8 754 05-02-2024, 11:21 AM
  delkevik slip on mufflers outback_imp 4 559 10-14-2021, 12:44 AM
Last Post: outback_imp
  Arrow slip on mufflers DougsZ28_imp 15 1,275 05-13-2021, 04:09 AM
  valve stem replacement without removing tyre max 5 567 01-08-2021, 10:46 AM
  Decat stock pipes ozigoo 4 477 05-22-2020, 10:55 AM
  Removing stock rack on 2014 quiffy_imp 10 712 05-17-2020, 01:23 PM
  Stock vs. aftermarket exhaust LongRanger_imp 15 1,086 11-30-2019, 06:30 AM
  Shaved Stock or K+H Low GroovyBunny86_imp 18 1,571 06-18-2019, 12:58 AM
Last Post: BayAreaRick_imp
