Turn Signal Swap - Blown Fuses
Elipten_imp Offline
Threads: 13
Just some more info. I was wiring on my 2014 Dlx yesterday installing aux LED lighting. I found there is a flaw in my bikes wiring for the rear turn signals. The lt blue and orange wires are the ground wires and the ground wires are actually the power wires. Completely opposite my 2013 std. Took me hours of trouble shooting and I double checked the wiring diagram. Thank you very much Honda for piss poor QAQC. I sweated in the Texas heat checking everything until the improbable became the probable.
07-27-2014, 10:17 AM
grover_imp Offline
Threads: 6
(07-27-2014, 08:59 AM)Ridem32_imp Wrote: If it's shorted to a ground yes would blow a fuse if it's shorted to another voltage wire no it would not blow a fuse it would cause whatever it was shorted too to come on maybe dim if it's another light etc
A ground is when a voltage wire touchs ground blows fuse. A short is when 2 voltage wires touch. It just depends on how you say it.
The cb1100 is not wired like the old cb750 as far as blinkers! The older honda bikes used a 1157 bulb up front so when the key was on the both front blinkers would burn as running lights using one element of the bulb. When the blinker was turned on the other side of bulb would light up and blink due to a signalstat the new cb1100 does not use 1157 bulbs ( double element bulbs) it uses a 1156 ( single element ) same as the rear blinker. The blinker wires run thru a control unit which turns on the single bulb for running lights. Then when blinker is turned on the controller makes it blink. I don't know if his bike when turned on if his running lights are coming on or if it's blowing a fuse with just the key on blinkers off!
Hey ridem,
At this point in just messing with the rears where I'm using the single filament (2 wire) LP turn signals.
07-27-2014, 11:57 AM
Ridem32_imp Offline
Threads: 51
When you turn on key does your front running lights come on? Does it blow fuse when you turn on right or left blinker? Or either?
07-27-2014, 12:04 PM
grover_imp Offline
Threads: 6
Front running lights aren't on initially, but when I push the signal there's an audible little snap when the fuse pops...
07-27-2014, 12:45 PM
Ridem32_imp Offline
Threads: 51
You have a 12 volt wire touching ground or you might have hooked up wires wrong and fired your turn signal control box. I sent you a PM with my phone #. You can call if you want and walk me thru each step you did.
07-27-2014, 01:13 PM
ChipBeck_imp Offline
Threads: 29
RE: Turn Signal Swap - Blown Fuses
I put those same signals on my bike and had the same problem. You can reverse wire one of them and they will still work when not bolted to the bike. But because they have metal housings the reversed one will blow the fuse once it's bolted on and you turn it on. You may also have a pinched wire that is grounding out when you assemble everything. I would guess you have one reverse wired and you think it's ok because it works when not bolted on.
Cheers.
Chip
07-27-2014, 02:53 PM
Razor Offline
Threads: 32
Likes Received: 58 in 13 posts
Likes Given: 15
Sounds like Ridem & Chip have you going in the right direction. Curious to know what you find. Thanks
07-27-2014, 08:54 PM
grover_imp Offline
Threads: 6
(07-27-2014, 02:53 PM)ChipBeck_imp Wrote: I put those same signals on my bike and had the same problem. You can reverse wire one of them and they will still work when not bolted to the bike. But because they have metal housings the reversed one will blow the fuse once it's bolted on and you turn it on. You may also have a pinched wire that is grounding out when you assemble everything. I would guess you have one reverse wired and you think it's ok because it works when not bolted on.
Cheers.
Chip
Yep, that sounds about right. I'll take another look and report back.
Thanks for the help guys!!!
07-28-2014, 12:15 AM
Kodeman_imp Offline
New to the Forum
Threads: 0
Sorry to bring an old thread back to life but i am having this issue on mine. What i found in the headlight is that the front blinkers are a three wire, Red, Black, and Black with a white stripe. The red is connected to the bikes blue/white wire and the Black/white is connected to the bikes green wire but the solid black is not connected to anything? Not sure the brand of these blinkers as they where on there when i bought it. Any ideas???
06-19-2018, 06:22 AM
12milesout Offline
Threads: 4
(07-27-2014, 06:34 AM)Razor_imp Wrote: If your connections are tight and insulated; I'd look to make sure you have the wiring connected as follows.
Left, Orange wire = 12v
Green = ground
Right, Light Blue wire = 12v
Green = ground
I'm guessing one side is correct, while the other is backwards. Each time the turn signal is enabled, the 12v feed goes to ground, causing the short.
Good luck, let us what you find.
(07-27-2014, 10:17 AM)Elipten_imp Wrote: Just some more info. I was wiring on my 2014 Dlx yesterday installing aux LED lighting. I found there is a flaw in my bikes wiring for the rear turn signals. The lt blue and orange wires are the ground wires and the ground wires are actually the power wires. Completely opposite my 2013 std. Took me hours of trouble shooting and I double checked the wiring diagram. Thank you very much Honda for piss poor QAQC. I sweated in the Texas heat checking everything until the improbable became the probable.
I ran into the same issue when wiring some motoGadget M-blaze LED's on my 2014 standard; the wiring in the rear was reversed (greens were hot, blue/orange were ground), but up front the greens were ground. Glad I had seen these posts prior to pulling things apart.
06-20-2018, 05:12 AM
  wheel swap cad cnc lazer reluctor for speed sensor 1973cb750 13 3,047 10-28-2025, 05:56 AM
Last Post: 1973cb750
  Turn Signal Indicators balkanhound_imp 5 642 04-17-2025, 11:17 PM
  2014 CB1100 Clear Turn Signal Lenses Ngavrielidis1_imp 16 1,448 04-15-2025, 06:23 AM
Last Post: Ngavrielidis1_imp
  Smaller turn signal/running light choices TxRonHarris_imp 33 2,480 07-06-2021, 10:00 PM
  Extra turn signal on dash Mixagon_imp 7 726 06-24-2021, 07:20 AM
Last Post: 17-CB-002
  Turn Signal Relocation Cormanus 11 858 12-30-2020, 11:12 AM
  best sprocket swap for city commuter acceleration... boynton6spd_imp 3 335 12-04-2020, 12:35 PM
  Wire Wheel / Cast Wheel Swap pekingduck 37 2,488 06-05-2020, 12:35 PM
Last Post: michael1954
  Signal Relocation Ben70_imp 7 746 02-20-2020, 10:22 AM
Last Post: Ben70_imp
  Turn signal relocation -- Making room for my backseat rider JMA_imp 13 988 06-15-2019, 12:44 PM
Last Post: QUINTtastic_imp
