Early 80’s handlebar clamp
Gone in 60 Offline
Blood Biker of the Apocalypse
Orange County, CA
Threads: 245
Likes Received: 1,218 in 523 posts
Likes Given: 985
RE: Early 80’s handlebar clamp
Aww man, I had started to look at those. As cool as that mod looks, it would mess with my visual peace. Could you get the lower clamps from the same 80’s bike so it all lines up? It would be more pieces to clean up and repaint.
08-18-2020, 12:18 PM
Likes Received: 887 in 486 posts
Likes Given: 1,020
I wouldn't like I, but I don't have the skill to do much about it.
08-18-2020, 12:32 PM
PowerDubs_imp Offline
Threads: 125
(08-18-2020, 12:18 PM)Gone in 60_imp Wrote: Aww man, I had started to look at those. As cool as that mod looks, it would mess with my visual peace. Could you get the lower clamps from the same 80’s bike so it all lines up? It would be more pieces to clean up and repaint.
Well- to be fair, that is the piece upside down with the stock cap sitting on it to etch a line.
When flipped over in proper position the new cap would overhang and most people probably wouldn’t notice.
I didn’t look back at the others clamps but they probably does this as well.
I’d have to see if there is a parts breakdown from almost 40 years ago.. but I’m going to guess the lower part back then was cast into the upper tree bridge.
I am just going to round off the lower corners to mate and try to blend best I can without going crazy.
No guts no glory.
08-18-2020, 02:55 PM
Desert viper_imp Offline
Threads: 7
Here is mine
08-19-2020, 02:15 AM
Gone in 60 Offline
Orange County, CA
Threads: 245
Likes Given: 985
Huh. Thanks for the description, PowerDubs, and the closeup, Desert Viper. If the upper bridge overhangs the lower part, and you wouldn't see the difference, that's fine with me.
I had aftermarket risers on my last BMW, and they were close, but not a great match for the BMW parts. Since it's a part of the bike you tend to stare at when you glance down at the gauges, for some reason it just messed with my Feng Shui.
Desert, the way you have yours finished is how I'd want to do it. Looks great!
08-19-2020, 02:25 AM
17-CB-002 Offline
Threads: 45
(08-19-2020, 02:15 AM)Desert viper_imp Wrote: Here is mine
Hi Desert Viper, a quick question.
Did you purposely omit the 4 chrome bolt caps or you like it better without the caps.
Regards
Alain Lee
On mine, the upper cap & lower bridge are flush (Perfect fit) Side to Side and Front to Back.
I guess HONDA can reuse older parts bins just like the horn.
[Image: 6f4aa73759fbacc8693298fbc416cdd2.jpg]
[Image: 931e287d002eb66672817214063a4339.jpg]
08-19-2020, 02:43 AM
misterprofessionality Offline
Threads: 126
Likes Given: 1
DV's version of the clamp is the one i saw on another bike i believe, as opposed to the one PowerD bought. it looks like it mates much more perfectly to the stock clamps. A+!
08-19-2020, 02:55 AM
peterbaron Offline
Likes Received: 594 in 325 posts
Likes Given: 1,004
EXCELLENT look!!
08-19-2020, 03:26 AM
Threads: 125
Alain that looks great. Thanks for the front on shot- that is what I will be shooting for!
08-19-2020, 03:27 AM
Threads: 125
So far so good.
I am certainly no machinist, I am just using a bench vice, a socket to keep it somewhat lined up and a Milwaukee cordless drill with a grinding bit.
I do have two large 240 V compressors and a die grinder, but I don’t wanna make a lot of noise and bother my wife and honestly for something like this slower is probably better.
[Image: 72dcb79fe90b53fab7f17d2f371504df.jpg]
[Image: 32c342999082e0aae3b36b922eba6c2b.jpg]
Still need to do the other side and then polish before spraying the clear.
08-19-2020, 10:39 AM
  USB ON HANDLEBAR - connection at battery direct . Alfgaxatico_imp 38 2,930 05-17-2026, 10:20 PM
  Quad Lock handlebar vs clutch perch and bar-end mirrors Uncle Sixer 1 331 01-04-2026, 01:26 PM
  Handlebar control symmetry Uncle Sixer 17 1,757 08-07-2025, 05:24 AM
  Handlebar Risers?? bubblerboy64_imp 16 1,535 07-16-2022, 06:04 AM
Last Post: calipo223_imp
  What to do with the handlebar mounts when converting to clip-on controls? misterprofessionality 7 763 04-08-2022, 03:41 AM
  CB 1100 EX Handlebar original or other? MALACAY_imp 4 552 04-03-2022, 01:00 AM
  Handlebar from 919 motorider6_imp 10 953 05-27-2021, 12:47 PM
Last Post: Stichill
  CRF1000 handlebar mspaansnl_imp 0 238 05-25-2021, 04:57 AM
Last Post: mspaansnl_imp
  HANDLEBAR RISERS - is really necessary??? Alfgaxatico_imp 19 1,498 12-16-2020, 10:40 PM
  More handlebar talk - Samurider Type 2 replacements GrabOn_imp 10 1,023 07-23-2020, 01:16 AM
Last Post: KiowaEagle_imp
