Went back to the dyno today...
PowerDubs_imp Offline
Threads: 125
Dynojet was nice enough to send me a run from a stock 2017 to compare-
[Image: e8532deff5a509fadd30ef6c1f830d2a.jpg]
As you can see- the difference ramps up and you get more the longer you hold on!
Not that an additional 7.25wtq and 4.52whp at 3,2000 RPM are bad.
The shop is used to doing sportbikes- I forgot to tell him the start the pulls low.
Ah, next time- I’ll be back!
11-11-2020, 10:25 AM
Likes Given: 1,010
RE: Went back to the dyno today...
Josh, does your bike really have 'custom Web cams'? Am I displaying my ignorance?
11-11-2020, 11:17 AM
Threads: 125
Yea- http://cb1100forum.com/forum/showthread....light=cams
They didn't do much- but I also picked a mild grind because I didn't want to loose power down low.
I try to look at everything as a package- even bigger, more aggressive cams could ultimately make more power- but in my opinion right now, the cams aren't the bottle neck...and making power is all about removing bottlenecks.
Which makes this all interesting- remove a bottleneck and other 'mods' could make more gains than initially thought.
My guess is next limitation is the throttle bodies. 32mm is small, especially for 1140cc.
11-11-2020, 12:16 PM
(11-11-2020, 12:16 PM)PowerDubs_imp Wrote: Yea- http://cb1100forum.com/forum/showthread....light=cams
Honda design spec likely targeted using 32 mm to meet the performance behaviour they were seeking as well as salvaging some economy. The stock CB1100 is surprisingly good on fuel consumption.
Honda knows how to make a 140 hp 1140 cc inline-4 (recall early 1980s). I reckon that wasn't the spec for these CB1100s.
11-11-2020, 01:37 PM
Threads: 125
Oh- I agree 1000%.
I'm not doing anything Honda couldn't do- they just had to contend with EPA for emissions and noise.
11-11-2020, 02:08 PM
Likes Received: 614 in 276 posts
Likes Given: 788
The 83 CB 1100F put out a reported 108 hp out of an 1062cc mill. That's a far cry from 140
11-11-2020, 02:18 PM
Threads: 125
(11-11-2020, 02:18 PM)The ferret_imp Wrote: The 83 CB 1100F put out a reported 108 hp out of an 1062cc mill. That's a far cry from 140
Crank or wheel?
My bike 'uncorrected' (true hp) put down a little over 106 so depending on what a person believes for drivetrain loss-
10% loss would be 118 crank.
15% loss would be 125 crank.
11-11-2020, 03:00 PM
Likes Given: 1,010
Dubs, I knew about your cams modification. I was just intrigued by the dynojet chart which referred to them as 'Web cams'.
11-11-2020, 04:28 PM
Threads: 125
http://www.webcamshafts.com/
11-11-2020, 10:21 PM
Likes Given: 788
Crank or wheel?
Crank or wheel?
I assume it was rated at the crank back in 83 and not dyno's. Maybe I can find a dyno chart for one.
Well couldn't find a dyno chart but found other sites listing the hp at 99 and 104.
Found these figures for the mighty 6 cylinder CBX which was faster than the CB 1100F
105 hp (78 kW)@ 9,000 rpm (claimed)
1978-1980 100–103 hp (75–77 kW) (claimed)
1981-1982 98 hp (73 kW) (rear wheel)
the V65 V4 Honda Sabre put out 121 hp (I imagine also measured at the crank)
There were no 140 HP inline 4's from Honda
11-11-2020, 11:13 PM
  Power Commander 5 and Dyno Tune iamheero_imp 7 580 07-18-2020, 04:14 AM
  ECU from Guhls/Dyno ready HikerToo_imp 120 9,720 04-16-2020, 07:53 AM
  Dyno results....Re-dyno after reflash? Waldo_imp 36 2,583 01-22-2018, 04:51 AM
  Best Dyno HP numbers? Kawiboy_imp 33 2,321 10-27-2016, 03:22 PM
Last Post: Ulvetanna_imp
  DYNO run today rusty1_imp 3 337 09-27-2016, 11:06 AM
Last Post: Jteakus_imp
  I need Dyno maps CIP57_imp 13 845 04-30-2014, 07:48 PM
Last Post: cade_f_imp
  Dyno Results Today 12cb96vfr_imp 15 1,088 02-15-2014, 01:39 PM
Last Post: SanPete_imp
  Wanted to share my map from my Dyno 12cb96vfr_imp 12 667 12-31-2013, 05:41 AM
Last Post: 12cb96vfr_imp
