Spools for pit stand.
mvk24_imp Offline
Threads: 18
Likes Received: 2 in 1 posts
RE: Spools for pit stand.
(03-21-2021, 07:52 AM)Houtman_imp Wrote: Depending on the type of spool YOU bought I used tapered bolts with alan type head so they are flush with the spool . I think that I bought them from Bolt Depot but not 100 % certain.
Sounds like thats the plan then, I like those vortex ones cause they're American made.
03-21-2021, 08:18 AM
Charlie Bravo_imp Offline
Threads: 30
I like a center stand on a streetbike; you never know when your gonna need to stand the bike straight up. I gas up sitting on the bike and get it full. My NTM Suzi doesn't have one, and it's annoying so I plan on getting one from ebay.
03-25-2021, 05:03 AM
Obleo Offline
Threads: 16
If the axel is hollow, you can run a threaded rod cut to the right length with washers and nuts set at the correct spacing. Tec products in England makes them for Triumphs . I fabricated my own as described above. Tech’s are permanently mounted but I use them for cleaning the chain and rear wheel on a 2020 Triumph Speedmaster with no center stand , remove them when finished.
03-25-2021, 12:09 PM
  Stand-alone ECU TTRacer_imp 2 307 02-22-2024, 01:58 PM
Last Post: TTRacer_imp
  Advice - carry water bottle and side stand plate? 4 Paws_imp 41 2,647 07-23-2022, 06:02 PM
Last Post: rich_imp
  Yoshimura RS3 Install. 2013 Kit on a 2014 and sorted the center stand issue! rdtshaw_imp 17 1,356 01-05-2022, 10:54 PM
Last Post: Nibis_imp
  Pit Bull Rear Stand Stichill 7 628 05-02-2021, 04:45 AM
Last Post: ampm7_imp
  Dimotiv Side Stand Enlarger - 2017 EX fit TXBikerGuy 5 638 08-08-2020, 09:48 AM
Last Post: TXBikerGuy
  Shorty pipe and center stand domeular_imp 53 3,454 10-28-2019, 02:10 AM
  side stand foot for 2017 Houtman_imp 7 627 09-17-2019, 08:13 AM
  Center stand mod for Yoshimura system Razor 9 771 09-06-2019, 05:20 AM
Last Post: Nemo_imp
  Center stand stop Nemo_imp 11 835 08-18-2019, 01:43 PM
  Kick Stand Pad - anyone else use one accassionally? Doug Shepard_imp 26 1,911 02-26-2019, 10:12 AM
