Center stand mod for Yoshimura system
Razor Offline
Threads: 32
Likes Received: 58 in 13 posts
Likes Given: 15
Purchased a Yoshimura full system for my 2014 Std. Left the center stand off because the spring return is in the center versus the side on the 2013 models. Some have cut the adapter plate and made it work. Thought I'd try to reuse the stand by making an extension off the pivot rod & exhaust bracket/hanger.
Here's some pics
Machined a piece that goes into the center stand pivot rod. Welded it to a piece of 1/4" x 3/4" flat stock, bent around in a "U". It'll make more sense later.
[Image: a657938218fe44c5d66b3a6fbcafa7e5.jpg]
Extension piece made from 1/4" x 3/4".
[Image: 1896990c8704f8bb5bbad67c7ef77a8e.jpg]
Aluminum spacer. Cut the rubber sleeve. Really tight fit.
[Image: b575c7588f587ec221e278066605c235.jpg]
Series of photos showing how everything came together
[Image: 6e3a23e50b8b29faab84601776a57533.jpg]
[Image: 519302c36cdd2b71425faa23e9fd9099.jpg]
[Image: 23ba1fd9a0b05466c2019e42fa647e59.jpg]
[Image: 727b044e06395d545fcc2acb45bf3f1c.jpg]
[Image: 8e762db5c960cab82533ffb9ba14283e.jpg]
10-17-2014, 04:15 AM
Rocky_imp Offline
Threads: 26
RE: Center stand mod for Yoshimura system
Very clever! Well done Thumbs Up Thumbs Up
10-17-2014, 04:26 AM
Likes Given: 789
Ingenuity at it's best. Way to go.
10-17-2014, 05:46 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
Looks like a business opportunity! Maybe a few guys on here will want one.
I sure would if I needed it.
10-17-2014, 06:16 AM
I think this whole thread is a fabrication. ROFL
i'll be here all week. don't forget to tip your waitresses.
10-17-2014, 06:17 AM
Razor Offline
Threads: 32
Likes Given: 15
Thanks, plan is to put a few miles and uses on the stand and make adjustments if needed. Then pull the two pieces off, clean them up & powder coat them.
(10-17-2014, 06:17 AM)EmptySea_imp Wrote: I think this whole thread is a fabrication. ROFL
MT, you are correct my friend Big Grin
10-17-2014, 10:05 PM
Lord Popgun Offline
Virginia
Likes Given: 142
They look pretty good now. Will look awesome powder coated!
You're killing me EmptySea Smile
10-17-2014, 10:21 PM
Nemo_imp Offline
Threads: 55
I would totally buy one of these, Ray.
08-18-2019, 11:04 AM
Exotica1_imp Offline
Threads: 1
RCVS exhaust comes with a new centerstand stop.
09-04-2019, 01:41 AM
Nemo_imp Offline
Threads: 55
(09-04-2019, 01:41 AM)Exotica1_imp Wrote: RCVS exhaust comes with a new centerstand stop.
I called Yoshi USA and bought the centerstand stop for my 2014. My stand no longer rests on the swingarm. All is good with the world.
09-06-2019, 05:20 AM
  Yoshimura RS3 replacement for an '13 Jurlie_imp 7 688 07-28-2024, 01:47 PM
Last Post: Glockrocks83_imp
  Stand-alone ECU TTRacer_imp 2 327 02-22-2024, 01:58 PM
Last Post: TTRacer_imp
  Exhaust system/slip-on johnny_elpino_imp 26 2,161 05-26-2023, 01:06 AM
Last Post: kzoorue_imp
  Yoshimura RSCV Full Exhaust System Stealth128_imp 43 3,894 11-29-2022, 10:38 AM
Last Post: mrded_imp
  Dart flyscreen and a little Yoshimura stain magic 1985CB450_imp 19 1,867 10-24-2022, 04:12 AM
Last Post: 1985CB450_imp
  Advice - carry water bottle and side stand plate? 4 Paws_imp 41 2,663 07-23-2022, 06:02 PM
Last Post: rich_imp
  Installation of a Smart Turn System [No Cut Mod] LayerCake_imp 20 1,843 06-15-2022, 01:28 AM
Last Post: KiowaEagle_imp
  Yoshimura RS3 Install. 2013 Kit on a 2014 and sorted the center stand issue! rdtshaw_imp 17 1,372 01-05-2022, 10:54 PM
Last Post: Nibis_imp
  DLX Exhaust System Conversion Ron in MO_imp 28 1,916 08-26-2021, 10:50 AM
Last Post: bvictory_imp
  hepco becker side back C system alexzanutto_imp 16 1,549 07-31-2021, 07:34 AM
