Spools for pit stand.
kmoney_imp Offline
Threads: 29
I decided to delete my center stand when I installed my new exhaust. It did come with an adapter bracket, but I never really liked the look of the center stand, and I don't really see the point of carrying the weight all the time for something that (at least me personally) I only use when in my garage. I decided to replace it with a pair of Vortex swingarm spools (m8 x 1.25) and a special adapter for my Pitbull rear stand (designed for the Norton Commando, but will work with basically any twin shock bike).
[Image: 6e51bb113d876e9fd1fe4bced0d0871f.jpg]
[Image: c50c3a21ed727c6124c7f4c97c6b8f86.jpg]
[Image: 53e3fef67456f562d048b2215ed0b363.jpg]
I definitely like it a lot better and I feel that it's much safer than having the clamps that just rest on the swingarm. The only caveat is that you will need an aftermarket exhaust can for this mod, as there definitely is no clearance between the stock and that shock bolt.
03-31-2016, 07:52 AM
Likes Given: 1,010
RE: Spools for pit stand.
Forgive my ignorance, kmoney, but can you get the bike onto that stand on your own?
03-31-2016, 06:45 PM
kmoney_imp Offline
Threads: 29
Yup. It's pretty easy. You put a block of wood under the side stand so that the bike sits closer to 90 degrees, straighten the front wheel (the bike rolls back a few inches when you raise it), slide the pit stand under the spools so they're just touching, and then just give it a light push down on the handle (I steady the bike with 2 hands from behind and use my foot on the handle) and it comes right up. Coming down is a bit harder, but you have enough leverage to not lose control.
03-31-2016, 09:26 PM
lash_imp Offline
Threads: 8
Kmoney,can you give me the dimension between the two lift arms ? I can't use a normal stand with my Wyverns because the stand interferes with the lower exhausts.
03-31-2016, 10:07 PM
Rebel73_imp Offline
Threads: 79
I want a setup like this as I don't like my center stand, either, but don't want to lose the functionality.
04-04-2016, 08:44 AM
Frulk_imp Offline
Threads: 108
Truth be told, I use my center stand mostly at the pump to get the max gas in the tank
04-04-2016, 09:43 AM
mvk24_imp Offline
Threads: 18
Likes Received: 2 in 1 posts
How have these held up? I would like to do this since my center stand was negated when I changed mufflers.
I've never seen the spool replace the suspension bolt but I guess thats the only option we have.
03-21-2021, 02:33 AM
Houtman_imp Offline
Threads: 115
Just buy the right spools and than figure the right and strong bolts to put them on , easy to do.
03-21-2021, 03:15 AM
mvk24_imp Offline
Threads: 18
(03-21-2021, 03:15 AM)Houtman_imp Wrote: Just buy the right spools and than figure the right and strong bolts to put them on , easy to do.
Yea I found these same Vortex spools on amazon.
So I could just grab like Grade 8 bolts myself so I know they're strong?
03-21-2021, 03:16 AM
Houtman_imp Offline
Threads: 115
Depending on the type of spool YOU bought I used tapered bolts with alan type head so they are flush with the spool . I think that I bought them from Bolt Depot but not 100 % certain.
03-21-2021, 07:52 AM
  Stand-alone ECU TTRacer_imp 2 296 02-22-2024, 01:58 PM
Last Post: TTRacer_imp
  Advice - carry water bottle and side stand plate? 4 Paws_imp 41 2,640 07-23-2022, 06:02 PM
Last Post: rich_imp
  Yoshimura RS3 Install. 2013 Kit on a 2014 and sorted the center stand issue! rdtshaw_imp 17 1,342 01-05-2022, 10:54 PM
Last Post: Nibis_imp
  Pit Bull Rear Stand Stichill 7 614 05-02-2021, 04:45 AM
Last Post: ampm7_imp
  Dimotiv Side Stand Enlarger - 2017 EX fit TXBikerGuy 5 634 08-08-2020, 09:48 AM
Last Post: TXBikerGuy
  Shorty pipe and center stand domeular_imp 53 3,443 10-28-2019, 02:10 AM
  side stand foot for 2017 Houtman_imp 7 623 09-17-2019, 08:13 AM
  Center stand mod for Yoshimura system Razor 9 759 09-06-2019, 05:20 AM
Last Post: Nemo_imp
  Center stand stop Nemo_imp 11 831 08-18-2019, 01:43 PM
  Kick Stand Pad - anyone else use one accassionally? Doug Shepard_imp 26 1,893 02-26-2019, 10:12 AM
