2014 Shift Lever Extension Modification, Replacement?
RE: 2014 Shift Lever Extension Modification, Replacement?
Wow, mega.
07-31-2021, 08:21 AM
Charlie Bravo_imp Offline
Threads: 30
(07-31-2021, 05:21 AM)HeavyMetalMech_imp Wrote: Here is the finished installation. It isn't a big deal but should make it more comfortable for those like me with thick toed boots and shifting. I didn't take a before picture unfortunately but it does extend the shift pedal almost 50%. The inside diameter of the extension didn't allow for a simple slide on over the rubber boot but I don't have to bother with the set screws that were included with the extension. It is larger than the pedal metal pin however. It can be easily be configured back to stock. To fit it on I pulled the rubber toe shift boot just a bit off the peg, sprayed it with silicon, stuffed the edge into the extension, and the extension did press on easily enough. It is very snug. I don't know how long the rubber rings around the extension will last or slide off. I may just keep a center one in place to keep the boot from being marked by the split metal of the ext. The extension does rotate well enough should shifting require it.
https://imgur.com/a/fIlrgQI
08-02-2021, 04:41 AM
HeavyMetalMech_imp Offline
Threads: 4
If you want to do it right, I would suggest buying the OEM shift lever, cut and file off the shift peg, drill and tap the flat, and find an aftermarket Harley or similar shift peg to screw into the tapped hole. A lot of options there. More than I want to do right now without riding it a while and maybe saving that for a winter project. I can't ask the forum as yet, because I don't have the prerequisite posts, but I would offer to buy a used lever off a wreck from someone here if possible. Thanks.
08-02-2021, 10:29 AM
  Rubber Lever End Thingies Cormanus 1,677 99,977 04-13-2025, 07:17 AM
  LED Headlamp Replacement Davidjill_imp 14 1,364 12-31-2024, 02:21 AM
  SHIFT AND BRAKE FOOT LEVERS omnimj_imp 14 1,187 09-23-2024, 12:56 AM
  Yoshimura RS3 replacement for an '13 Jurlie_imp 7 625 07-28-2024, 01:47 PM
Last Post: Glockrocks83_imp
  Value of Seat Modification clc0000 39 2,611 02-13-2024, 11:02 AM
  Hepco Becker Replacement Key tomcat_imp 5 573 08-10-2023, 03:20 AM
  A small modification i stole from EmptySea misterprofessionality 21 1,334 04-20-2022, 05:56 AM
  Wrecked my CB, need OEM or Aftermarket replacement suggestions danieljrmurray_imp 12 860 09-15-2021, 05:51 AM
Last Post: teamvisegrip_imp
  Brake lever guard for track days mrded_imp 17 1,215 05-26-2021, 07:50 PM
Last Post: mrded_imp
  hard bag modification Chuckk_imp 30 1,956 03-10-2021, 01:35 AM
