Brake lever guard for track days
mrded_imp Offline
Threads: 7
Likes Received: 2 in 2 posts
Hello, can you recommend not alien looking lever guards for cb1100?
Most of them look too sharp/bright designed for sport bikes. I’m looking for something almost invisible and matching my RLETs.
It’s a requirement for track days, so I have to install them. Thanks.
01-05-2021, 11:38 AM
RE: Brake lever guard for track days
(01-05-2021, 11:38 AM)mrded_imp Wrote: Hello, can you recommend not alien looking lever guards for cb1100?
One of the sanest things read all day.
01-05-2021, 12:35 PM
jimgl3_imp Offline
Threads: 27
them? never heard of a clutch guard... front brake lever, yes. who cares what it looks like. take it off after.
guess things are changing. it has been 6 years since I've raced or done track days, but even WERA did not "require" them when I was racing...
nope. WERA still has no such requirement.
01-05-2021, 02:07 PM
mrded_imp Offline
Threads: 7
(01-05-2021, 02:07 PM)jimgl3_imp Wrote: them? never heard of a clutch guard... front brake lever, yes. who cares what it looks like. take it off after.
If I don’t care how it looks like, I won’t be riding CB1100.
01-05-2021, 06:49 PM
jimgl3_imp Offline
Threads: 27
If you care what it looks like, don't take it on the track. the whole reason the brake guard would be required is due to the high potential for collisions on the track!!!
01-09-2021, 01:44 PM
mrded_imp Offline
Threads: 7
I wanted to try a track, and I don’t have another bike unfortunately. As I understand the brake lever protection is required now, and I will be to lazy to remove it after track days. That’s why I wanted to install and keep it.
I’ve seen some lever guard which can be converted into wind guards easily.
Or, bar end mirrors. Can those be used on track as lever protectors?
01-12-2021, 11:00 AM
Charlie Bravo_imp Offline
Threads: 30
It's your bike and you can do with it what you will, but a CB1100 as a track bike? Track bikes should be like winter cars, i.e., dings and dents and scratches here and there, but running good with the right tires. I would not risk my CB on a track, because the whole reason for track days is so you can ride it balls-to-the-wall and not worry about laying it down, assuming you have the leathers, etc. You can get a track bike pretty cheap when riders want to move up a class and the old mount is for sale. Good luck to you.
01-14-2021, 05:29 AM
mrded_imp Offline
Threads: 7
Ok, whatever I get my CB1100 to a track or not - is a different discussion.
I've bought myself a pair of barkbusters AERO-GP Lever Protector. Which come with wind protectors, very nice.
And found several problems:
- Stock bar ends are rotating, along with an anti-vibration long tube inside the handlebar. Looks like I need to replace everything, in order to add lever guards.
- Do I actually need bar ends weights? I see some people are removing them, and seems happy. The engine is very smooth, and doesn't vibrate a lot.
- If I need bar ends weights, how can I add it together with lever guards I bought?
Just wanted your thoughts on that ^ till I do something wrong.
Related discussions:
- [url=http://cb1100forum.com/forum/showthread.php?tid=15154]http://cb1100forum.com/forum/showthread.php?tid=15154
- http://cb1100forum.com/forum/showthread.php?tid=11229
- http://cb1100forum.com/forum/showthread.php?tid=8589
01-29-2021, 10:14 AM
peterbaron Offline
Likes Received: 590 in 323 posts
Likes Given: 996
...and what about RLETs, none ?????
01-29-2021, 12:27 PM
How much wind do these actually shed?
01-29-2021, 12:57 PM
  Foolish or Reasonable: R&G Oil Cooler Guard rdprdp01 2 454 04-14-2025, 05:16 PM
Last Post: deuce17EX
  Rubber Lever End Thingies Cormanus 1,677 102,284 04-13-2025, 07:17 AM
  Foolish or Reasonable: R&G Oil Cooler Guard rdprdp01 11 949 04-11-2025, 02:41 PM
Last Post: rdprdp01
   Tank Guard Options Yata-Garasu_imp 11 704 05-18-2022, 08:11 AM
  Front Fender Splash Guard Wagonpeddler_imp 26 1,630 03-03-2022, 05:45 PM
Last Post: jtopiso_imp
  2014 Shift Lever Extension Modification, Replacement? HeavyMetalMech_imp 12 1,054 08-02-2021, 10:29 AM
Last Post: HeavyMetalMech_imp
  PLOT Chain Guard KiowaEagle_imp 14 1,113 09-30-2020, 12:31 PM
Last Post: tod.branko_imp
  we know this engine guard ? alprider 1 305 06-27-2020, 07:32 AM
  Oil Cooler Guard Chris Goldson_imp 10 912 11-09-2017, 11:41 AM
Last Post: Dvassino_imp
  SW-MOTECH Engine Guard 17-CB-002 4 479 08-03-2017, 07:13 PM
Last Post: Rocky_imp
