Tires ~ Converting tube to tubeless type.
17-CB-002 Offline
Threads: 45
RE: Tires ~ Converting tube to tubeless type.
According to Mr. T from Samurider, the correct part # is:
OUTEX kit for both Front and rear.
http://outex.jp/?pid=75166908
Hope it helps
Alain
03-11-2019, 12:06 PM
Likes Given: 1,016
Alain, I assume you've also been following [url=http://cb1100forum.com/forum/showthread.php?tid=13854]this thread.
03-11-2019, 12:54 PM
17-CB-002 Offline
Threads: 45
Thanks Cormanus.
Did review the thread, however, I am still a bit confused.
My confusion is: Can I directly & SAFELY use a tubeless tire on a rim designed for tube type tires?
Thanks
03-12-2019, 12:44 PM
Likes Given: 1,016
Alain, I can't answer that, but the experience of those members of the forum who have converted spoked rims is that you can. However, I suspect it requires that the bead around the wheel itself is sufficient to hold the tyre without its leaking or popping off. CA200 would know. So, too, may AussieFlyer. And, no doubt, others.
03-12-2019, 01:43 PM
Aussieflyer Offline
Threads: 17
Likes Received: 5 in 1 posts
Alain,
our CB1100 spoked rims have safety bumps on the inside of the rim such that the tyre should not easily fall inside the rim ... which would be a huge issue for a tubeless tyre! These bumps are a slightly raised surface that runs around the rim inner just to the inside of the landing area where the tyre bead sits. This feature is a common method for the safe 'seating' of tubeless tyres. After sealing the spoke nipples in the rim a tubeless tyre should install and operate safely on these rims. I took the gamble and converted my spoke wheels to tubeless tyre a couple of years ago. So far no issues on the two sets of tyres I have used over the past 5 or 6 thousand Kms.
03-12-2019, 06:09 PM
Likes Given: 1,016
AF, what are your wheels? Are they CB1100 originals from the EX?
03-12-2019, 07:12 PM
Aussieflyer Offline
Threads: 17
(03-12-2019, 07:12 PM)Cormanus_imp Wrote: AF, what are your wheels? Are they CB1100 originals from the EX?
Yes mate they are originals off the EX model.
03-12-2019, 10:49 PM
Likes Given: 1,016
Likely to be the same for the ‘17 model methinks.
03-12-2019, 10:59 PM
17-CB-002 Offline
Threads: 45
(03-12-2019, 06:09 PM)Aussieflyer_imp Wrote: Alain,
Thanks, what Make/size tires did you use after the conversion?
03-18-2019, 08:23 AM
Venteuri_imp Offline
Threads: 1
BUMP! ... I am waiting on the Outex thing to seal my rims. What size tires are you (outex tubeless conversion) using on the rear? I am thinking on staying with the 140/70 for safety concerns... but wonder if 160/60 is ok to use?
02-11-2024, 05:44 AM
  Tubeless tires pittycheria_imp 77 5,701 05-30-2023, 09:31 PM
  Tube type/size KubaGrom_imp 12 992 02-27-2023, 02:44 PM
Last Post: Mafd2_imp
  What to do with the handlebar mounts when converting to clip-on controls? misterprofessionality 7 755 04-08-2022, 03:41 AM
  More handlebar talk - Samurider Type 2 replacements GrabOn_imp 10 994 07-23-2020, 01:16 AM
Last Post: KiowaEagle_imp
  Type 2 Handlebars Installed Capo 4 483 09-21-2018, 07:02 AM
  CB1100 Type II Conversion Guth_imp 26 1,843 01-22-2018, 05:39 PM
Last Post: Guth_imp
  CB1300 Aluminum three-point type of security rod, fitted 2014CB1100 Good protection jp4141432_imp 2 480 09-26-2016, 08:56 PM
Last Post: jp4141432_imp
  Handlebar Type II holy666diver_imp 11 897 07-11-2016, 04:35 AM
Last Post: Papa Weeley_imp
  Installing Honda Type II bars... Rebel73_imp 9 828 04-18-2016, 07:56 AM
Last Post: Rebel73_imp
  120-80/18 tubeless endure tire...anyone? Ferrealls_imp 2 399 06-25-2015, 02:20 AM
Last Post: lemontree_imp
