Valve Adjustmant
My experience with shim under bucket adjusters is that they rarely need adjustment. My Triumph Tiger 1050 was always in spec when checked every 12000 miles. A bike that needed shims changed at the first check was most likely out of spec since new. Older type shim over bucket systems as in my old Fiat needed resetting more often perhaps because the cam lobes acted directly on the shims. I know of at least one Tiger 1050 with valves still in spec after 75000 miles. At least the valves on the CB1100 are easy to check since there is little to remove for access other than the tank.
  Valve Adjustment Shims dave 13 708 07-28-2026, 12:49 PM
Last Post: MagnaRider
  Valve Adjustment and Camshaft Removal dave 5 633 03-21-2026, 04:49 PM
  Valve Adjustment dave 6 865 08-29-2025, 10:46 AM
  Valve Cover Baffle lining ? bflint 6 945 07-26-2025, 11:27 AM
Last Post: bflint
  Valve Adjustment Intervals CBRider_imp 32 2,970 04-21-2025, 02:24 PM
Last Post: Jurlie_imp
  Valve Adjustment Tolerances - How Far Do You Go? dave 14 1,526 10-18-2023, 09:28 PM
Last Post: The Gecko_imp
  Observed Valve Clearance Cormanus 16 1,450 03-06-2023, 09:03 AM
Last Post: Tejas_imp
  The OBSERVED Valve Clearance thread Pterodactyl_imp 162 12,828 12-27-2022, 08:35 AM
  Checking valve clearances Maturecheese_imp 74 6,527 12-11-2022, 12:56 PM
  Valve noise (i think) Maturecheese_imp 6 649 07-08-2022, 03:41 AM
Last Post: 1973cb750
