Valve Adjustmant
Has anyone had to adjust the valves yet? I know that the manual says check them @ 8k but i was wondering if anyone has had to actually change shims...
I believe Gcarver had to have all of his exhaust valves re shimmed, they were all loose.
I believe RandyB's were all in spec when he had his checked
Not sure anyone else has had it done
Thanks Ferret! I will follow that...
I may try to go 12K miles before I have mine checked....
I used to do them myself on my 900 Ninja, but I was younger, more ambitious and had less money, also the cams did not need to come out, just turn a screw.
(12-01-2013, 07:14 AM)HikerToo_imp Wrote: I may try to go 12K miles before I have mine checked....
Hiker....yes the CB750s have tappets for valve adjustment... The 1100 will be a little more involved plus you will have to stock some various size shims ahead of time....or i guess you can do a check then stop what you are doing and go to the dealer and buy just what you need( i hate having having to stop and start a project for parts) Personally i would rather keep a small stock on hand then just use what i need.
You don't need to remove the cams just to check the clearance; you only need to remove them to change shims if they are out-of-spec.
I'm coming up on 8,000 miles, so I'll need to check mine or get 'em checked pretty soon. I'll keep ya'll posted.
(12-02-2013, 11:07 AM)Rolls_imp Wrote: I'm coming up on 8,000 miles, so I'll need to check mine or get 'em checked pretty soon. I'll keep ya'll posted.
Rolls....To check the clearance it is a pretty simple task ...cold engine remove the tank and valve covers ,remove the cover on the flywheel side find the timing marks... look for TDC (the other set or marks are for ignition timing advance) turning the engine in the direction that it runs.I start with TDC on the compression stroke of the #1 cylinder you will be able to tell compression stroke by the fact the cam lobes (Intake and exhaust) will be at there flattest in relation the the valves and there will be a little clearance at the cam and valve (both intake and exhaust at the same time) Then follow the firing order for checks of the next three cylinders....And btw az is right you dont have to pull the cams out for a simple check.... Clap
BTW The valve clearances are:
IN 0.15 +/- 0.03 MM (.006 +/- .001 in)
EX 0.28 +/- 0.03 MM (.011 +/- .001 in)
From the shop manual….
A heads up to good people. When I went to the service department at Rosenau Powersports in Dearborn Heights for shims for my F4i's valve adjustments they just traded me straight up for what I needed. The mechanic would just pull out the shim box give me the sizes I needed, mike my old shims and put them back.
  Valve Adjustment Shims dave 13 709 07-28-2026, 12:49 PM
Last Post: MagnaRider
  Valve Adjustment and Camshaft Removal dave 5 635 03-21-2026, 04:49 PM
  Valve Adjustment dave 6 868 08-29-2025, 10:46 AM
  Valve Cover Baffle lining ? bflint 6 951 07-26-2025, 11:27 AM
Last Post: bflint
  Valve Adjustment Intervals CBRider_imp 32 3,010 04-21-2025, 02:24 PM
Last Post: Jurlie_imp
  Valve Adjustment Tolerances - How Far Do You Go? dave 14 1,545 10-18-2023, 09:28 PM
Last Post: The Gecko_imp
  Observed Valve Clearance Cormanus 16 1,453 03-06-2023, 09:03 AM
Last Post: Tejas_imp
  The OBSERVED Valve Clearance thread Pterodactyl_imp 162 13,120 12-27-2022, 08:35 AM
  Checking valve clearances Maturecheese_imp 74 6,562 12-11-2022, 12:56 PM
  Valve noise (i think) Maturecheese_imp 6 649 07-08-2022, 03:41 AM
Last Post: 1973cb750
