Smooth Power Everywhere II
Pterodactyl nailed it. I rechecked the nuts on my exhaust headers, found a couple on the loose side and retightened all four pipes.
I did a 40 mile ride and all was well. No pops whatsoever.
Had a few opportunities to nail it and the bike gets very serious above 6500 rpm. Hang on!
The engine is doing everything it's asked and then some. Lopping along at 2000 rpm in 5th gear and it goes right up and over some decent hills without bogging down.
The stock PCV map is handling the modification awesomely. Thanks for everyone's help as always. Supercruz - as Vic said in his thread, you can' t go wrong with a PCV.
Obligatory picture taken today at a local golf course.
[Image: f4af183a49e13ef9ffb11b8fd63b93ab.jpg]
Your bike really looks nice!
Lets say you decide to remove the PCV and go back to stock tune and setup. What is the procedure?
(04-07-2014, 11:36 AM)SUPERCRUZ_imp Wrote: Lets say you decide to remove the PCV and go back to stock tune and setup. What is the procedure?
I would hope the stock ECU recognizes the changes.
Yesterday I rode the pants off the bike and again encountered popping in the exhaust, but only when lifting off the gas when shifting from 1st to second at redline.
My son-in-law is going to find out who dyno tunes his buddies bikes. It may be a while (I just spent 6 figures on a driveway) but I'll eventually post some results.
Yea, but most of them were zeros weren't they?
( you will love a solid driveway!)
Simple as pie. Just unplug the PCV and restore the wiring to original, and reinstall all original components.
The PCV stores nothing in the ECU memory. That would be the thing about an ECU flash, it's going to require another reflash to put the thing back to stock settings if you wanted to do that.
Installed my PCV last night. Two hardest parts were removing the fuel line from the tank and routing the PCV wire harness through the frame. Finally figured out how to just squeak the plugs by the frame tube down low on the left side and then run up by the tank. Everything fits very nice and neat the the PCV is a solid and well built piece in my opinion. Plugs and wiring are first rate. PCV fits very nicely into the cubby holder behind the tank. Still have room for my tools and rags.
Bikes fired right up and ran smoothly. I rode the bike to work today and put about 50 miles on in mixed heavy traffic and highway speed use. Bike idles at just a bit over 1,000 RPM warm (say 1050). Just off idle in slow stop and go is very smooth. Bike has very smooth throttle in all gears and pulls like a freight train from say 50 - 90mph+. I nailed it at coming home for lunch today and the bike is very fast. I am running an Arrow slip on muffler and a K&N filter. No other mods. There is a slight bit of popping on decal but attribute that to the air injection. Have not decided to close that off yet.
I think with the slip on and filter, the PCV has met my expectations. Would I put it on a stock bike? Not sure. My bike ran so well in stock form. I had nothing to complaint about.
(04-05-2014, 07:42 AM)CB4ME_imp Wrote: I didn't want to hijack Vic's great thread so I started another.
I also added a PCV to my bike.
I'm running the stock MAP on the Power Commander. No auto tune.
Idle is 1100 rpm. Just like Vic's bike, no hesitation, no jerky response, smooth accel from low revs right up to redline. And the bike has had a few performance mods - TSR air funnel, K&N filter, MotoGear headers and Staintune. Pretty darn amazing.
The only thing different I've noticed, besides wrist bending performance when the throttle is exercised, is an occasional single mild pop between gears when upshifting at a leisurely pace. Any idea what's causes this - besides the fact that the PCV is running a stock MAP? Lean, rich?
Other than that, it's the same well mannered power plant, comfortable cruising around at 2500 rpm in 5th gear with plenty of power going up hills.
[Image: 24d38e41a50c4112bf5972e585027299.jpg]
Hi CB4ME, great-looking bike! I'm waiting to accept delivery on my 2014 Deluxe, but I would like to ask you about your fairing, and luggage-rack / sissy bar because these are two options I intend to install on my bike. What brand of fairing is this? Is that a Honda rack that you modified by attaching the sissy bar to like was shown in a different thread in this forum? Do you have the sissy bar because of a passenger? If yes, can you please comment on your passenger's comfort while riding with you? Thank you.
Dave - congratulations on your 2014 Dlx. I'd love to see one with a fairing.
The fairing is a Chic Design Road Comet I made for the 2013 model. Chic Design also has the Road Comet II which is a bit more angular. They are offered unpainted, painted - and for a premium - painted with stripes.
I got mine from Samurider. Takashi, the owner, said Chic Design is offering these fairings for the 2014, modified to acccomodate the higher headlight position and to match the slightly deeper red color.
I have a 2013 Honda rear carrier. The 2014 Dlx needs the newer 2014 carrier (23,000 yen on Samurider).
[Image: a78efe6c47726625e86bffbb1a526d20.jpg]
I added a Jardine mini backrest to the rear carrier for my wife. She's uncomfortable without it. The Jardine should fit inside the rear carrier and there seems to be plenty flat surface to drill a couple holes in it. You'll need to fabricate a mounting plate to connect the carrier to the sissy bar. The Jardine uses 10mm mounting bolts.
[Image: 5184b19eb01e7718407bd9e5df53e247.jpg]
The rear carrier and sissy bar may detract from the clean lines on the CB1100, but the backrest provides for passenger comfort and safety, and the rack lets us carry a small roll bag.
CB,
The popping is being caused by the PAIR valve system.....
http://cb1100forum.com/forum/showthread....light=PAIR
Block it off and the popping will stop..
You may also want to try the TSR map....
  GPS power cable The Gecko_imp 10 1,023 10-06-2023, 12:40 AM
Last Post: suhawk305
  Has anyone installed a power commander in? Doug Shepard_imp 3 501 08-10-2023, 07:20 AM
  Power source for oil indicator led norton1974_imp 1 277 12-31-2022, 10:07 AM
  Power Commander V question HBFL_imp 1 258 08-23-2022, 05:41 PM
Last Post: jtopiso_imp
  Power Commander Tune Maps. mvk24_imp 43 3,054 01-03-2022, 08:16 AM
Last Post: SoCal CB1100_imp
  2010 model Power Commander alternative? 83NZA_imp 7 617 08-03-2021, 02:04 PM
Last Post: Aussieflyer
  Smooth shifting DougsZ28_imp 16 1,365 07-09-2021, 07:32 AM
  Transmission power routing and speeds LakeWylieJoe_imp 6 640 01-10-2021, 10:30 AM
Last Post: jimgl3_imp
  Guhl Reflash vs. power commander with custom map. misterprofessionality 9 760 09-06-2020, 03:59 AM
  Cheap airflow / power gains PowerDubs_imp 7 610 07-21-2020, 01:59 AM
Last Post: Cobalt23_imp
