Power commander install
Did everyone remove their fuel tank when installing their PCV, or were you able to prop up the tank enough to get to the connector that sits underneath? Fuel tank removal seens easy enough, but I'd prefer not to have to empty the tank.
I removed the tank, the vent tube is easy to remove the main fuel line I found a little trickie but got there in the end, it self seals so no need to drain the tank....... Made it easier to access the main connector under the tank and running the power commander loom....
(12-23-2013, 05:49 AM)Smiler_imp Wrote: I removed the tank, the vent tube is easy to remove the main fuel line I found a little trickie but got there in the end, it self seals so no need to drain the tank....... Made it easier to access the main connector under the tank and running the power commander loom....
Thanks! Just ordered one.
This^^^^^^^Clap
It took me about an hour to do. The YouTube video Dynojet posted is quite helpful, but little things like figuring out the fuel line disconnect and how to run the two power commander plugs behind the frame (it is super tight) added some time.
(12-23-2013, 06:50 AM)HondaJon_imp Wrote: It took me about an hour to do. The YouTube video Dynojet posted is quite helpful, but little things like figuring out the fuel line disconnect and how to run the two power commander plugs behind the frame (it is super tight) added some time.
Those were the 2 items that slowed my install as well. I was shocked how difficult it was to get the plugs through the frame. Otherwise it's a breeze.
I ran the plugs over the frame next to the rear tank mount....no biggie.
I installed my PCV this past weekend. I found the fuel line the trickiest part. I think this took me a half hour to figure out.
Getting the plugs behind the frame worked for me by threading the connector plugs through at the lowest possible point and then working the cables up to the top of the frame. Under five minutes. Definitely a tight fit though.
I am running the stock oil filter and exhaust (at this point). It may be my imagination, but the the bike feels way more responsive post PCV install. The bottom end feels like far more power then pre PCV.
(01-07-2014, 08:46 AM)CDN_RIDER_imp Wrote: I installed my PCV this past weekend. I found the fuel line the trickiest part. I think this took me a half hour to figure out.
what is about fuel mileage PCV installed?
Once I figured it out I also threaded the connectors at the lowest point and it was a comparative breeze.
Everything I've read says Honda tuned the bike to run lean to meet emissions standards (and increase MPG). I think the PCV corrects this lean condition. I hope to test mine in a week or so.
  Delkevic 9" Oval Install Problems. jbird06_imp 4 443 06-11-2024, 08:25 AM
Last Post: devildogdoc_imp
  GPS power cable The Gecko_imp 10 913 10-06-2023, 12:40 AM
Last Post: suhawk305
  Has anyone installed a power commander in? Doug Shepard_imp 3 467 08-10-2023, 07:20 AM
  Install a 6-speed trans on a 2013? amacbeth_imp 37 2,999 02-21-2023, 12:22 PM
  Power source for oil indicator led norton1974_imp 1 258 12-31-2022, 10:07 AM
  Power Commander V question HBFL_imp 1 234 08-23-2022, 05:41 PM
Last Post: jtopiso_imp
  17 tooth CS sprocket install, comments. Bike #12_imp 11 874 01-03-2022, 08:30 AM
  Power Commander Tune Maps. mvk24_imp 43 2,852 01-03-2022, 08:16 AM
Last Post: SoCal CB1100_imp
  Tail light install problem iamheero_imp 9 643 11-27-2021, 02:58 AM
Last Post: Bazbro_imp
  2010 model Power Commander alternative? 83NZA_imp 7 537 08-03-2021, 02:04 PM
Last Post: Aussieflyer
